Oil pressure light
alinghi9 Apr 18, 2012
  1. alinghi9
    alinghi9 Member
    67
    Hi
    oil pressure lamp came on the other day, showing "min" on the dash, have filled up the oil in the car to the max level, but the light has not gone off? does it need to be reset or should it automatically realise?
  2. Graham89
    Graham89 Derv Perv
    310
    That will be level light and not pressure light. Mine flashed up and after a quick top up it went out on it's own. Hope this helps
  3. alinghi9
    alinghi9 Member
    67
    yeah i topped mine up, but its still on even after i have driven around.
    any other tips?
  4. VWAddict
    VWAddict Member VCDS Map User
    656
    9
    PRESSURE?
    I repeat...
    PRESSURE?
    If its oil PRESSURE, you need to shut the engine off... -IMMEDIATELY. Call for a tow vehicle. There is NO other acceptable option.
    If it's oil level, you need to learn the difference.
    Oh, and check oil level every other time that you open the gas cap.
  5. IceHanger
    IceHanger Active Member VCDS Map User
    340
    64
    yup...normally if you see that light it's too late
