Oil pressure light is on & three deadly beeps!
S3KO4 Mar 7, 2011
  1. S3KO4
    S3KO4 Member
    850
    Right, I removed the inlet manifold to clean up and noticed the oil breather pipe underneath it had a 2" cut in it so I replaced it, the car feels a lot quicker but after 5 minutes driving the oil pressure light comes on/off. Big red sign and three beeps!
    it doesn't do it at idle only when driven mainly above 2k rpm or when boost comes on.
    My guess is the oil pick up is blocked, car has done 141k and last oil was changed in July.
    Can anyone please shed some light on this. or if you previously had this issue!
    could this be the oil pump? I hope not. p.s. sensor looks ok.
  2. finesse
    finesse Active Member
    2,805
    for peace of mind don't drive - check oil pump & pickup pick up pipe health
  3. Biggied
    Biggied They called him mellow yellow.
    198
    Blocked strainer mate, I wouldn't even start the engine again until you've had the sump off for a look.
    Ewan.
  4. beachbuggy
    beachbuggy Well-Known Member
    1,931
    201
    You didn't knock off the oil pressure sensor wiring or possibly break it when you took the manifold off? If the sensor isn't connected it will give you the same warning. Worth checking 1st. Failing that it'll be the pickup and possibly pump.
  5. S3 TAM
    S3 TAM Pocket now empty
    624
    10
    Don't start engine, check pick up. mine blocked last year driving down the M11, new pump pick up and turbo lots of ££££
  6. S3KO4
    S3KO4 Member
    850
    Thanks guys I shall start cleaning the sump and the pick up. can't afford an oil pump. do you guys know where I could get one cheaper. and can't seem to find the guide to remove the sump!
  7. S3KO4
    S3KO4 Member
    850
    I had a quick look it doesn't seem like I have broken anything, and like I said the light comes on only when driving it above 2000RPM. if it was the sensor surely it would stay on all the time.
  8. superkarl
    superkarl MAN OF STEEL
    9,468
    2,427
    how does the engine actually sound???
  9. S3KO4
    S3KO4 Member
    850
    sounds really good until 3k rpm, and sounds rough after that, the difference in sound is noticed especially when on load.
  10. danger S3
    danger S3 Member
    369
  11. finesse
    2,805
    I think tuffty just bought an oil pump from gsf.
    good luck with solving it,
  12. beachbuggy
    1,931
    201
    Nope sensor only show low oil pressure above a certain rpm
  13. superkarl
    9,468
    2,427
    All rattly at the top end? Not good that :( I had it once.
  14. aragorn
    18,313
    808
    the dash ignores the pressure warning below 2k rpm.
  15. S3KO4
    S3KO4 Member
    850
    Ah never new that, I will triple check again, see if I have left anything off. many thanks for all your inputs.
  16. jojo
    28,885
    3,537
    Same thing happened on my mates Passat 1.8T, and the engine was fubar'd soon after, don't drive it!
  17. DenCar
    DenCar Member
    404
    Hope you get sorted, just as a matter of interest what oil have you been using?
    DC
  18. S3KO4
    S3KO4 Member
    850
    checked all the sensors again with no issues, light still comes on.. tomorrow will be taking the sump off
  19. S3KO4
    S3KO4 Member
    850
    I am using 5w40 fully synthetics all the time, but I have changed my last oil in July last year, and prior to that the engine had no smoke added as I had silly blown turbo seals so added the **** to pass MOT! I think that has further restricted the flow.
  20. S3KO4
    S3KO4 Member
    850
    Got a new pickup pipe after 1.5 hour on the bike, GSF no, Audi No, VW no, VW TPS yes :)
    While working on the car a lovely neighbour had informed the council(Westminster) so I was being videoed and recorded by the stupid smart cars! What can they do I didn't make much of a mess & no noise! And does any one know the rules around this?
    If I knew I would have used a better sump, + forgot about the oil return gasket so used the same sealant I hope it wont leak..
  21. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    Good you got to the problem mate! Can't believe a neighbour would report that!
  22. Welly
    Welly VX220 SC Driver :)
    10,696
    128
    Hmmmm, that would be the bell end neighbour that everyone has then...
  23. S3KO4
    S3KO4 Member
    850
    Screw them.. I was too busy trying to put the damn thing back on otherwise I would have gone up to the stupid car see what the problem was!
  24. S3KO4
    S3KO4 Member
    850
    I still don't know if the problem is curred, as I couldn't undo the oil filter, and my oil was in the post. I will find out tomorrow.
    Maccabee33 likes this.
  25. aragorn
    18,313
    808
    TBH, that doesnt look bad enough to cause any problems.
    Whats the deal with the council? Are you suggesting that working on your car in the street is illegal now?!!?
  26. aragorn
    18,313
    808
    Had a quick google.
    Seems there is an act in place (Clean Neighbourhoods and Environment Act 2005) which places restrictions on work which can be done on the street, however it does say:
    The offence of repairing a vehicle is not intended to target private individuals who are carrying out minor work to their vehicles (unless the repairs cause unreasonable annoyance to persons in the vicinity), or those who carry out necessary work to vehicles by the side of the road in order to get them moving again after a breakdown or accident (such as breakdown organisations and mobile mechanics), provided the work is completed within 72 hours. Authorisation to carry out repairs to a motor vehicle on a road at a later date following a breakdown or accident can be granted by a local authority within the 72 hour period.
  27. quattro1
    quattro1 Member
    639
    Have you got any idea who reported you? Id print off that paragraph and post it through their door! Along with a turd!!
  28. DenCar
    DenCar Member
    404
    I Agree, doesnt look too bad at all!!
    DC
  29. S3KO4
    S3KO4 Member
    850
    At first I didn't think it was bad but when you look closer almost every hole in the mesh had that sandy things stuck in it. So I hope that was all needed doing. and thanks for checking up on the act 2005.
  30. S3KO4
    S3KO4 Member
    850
    :) I have an idea who it is, but I can't assume without hard evidence, even better next time I will print it in font 72 and stick it on the windows
  31. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    It will probably be someone whos just got their bill from audi....
  32. DenCar
    DenCar Member
    404
    Or a Service Manager from Audi
    DC
  33. Biggied
    198
    I've seen plenty of strainers that didn't look to bad but were restricting oil flow alot, TBH I think the oil pressure light can come on @ idle but the reason they usually don't is becasue the restriction is only shows up when theres more flow needed as the revs build.
    Also the act of 2005 that prevents working on your car in the street only applys in England, I'm away to drop my engine in the steet just because I can lol.
    Ewan.
  34. S3KO4
    S3KO4 Member
    850
    I have put everything back on. and the light still comes back on.
  35. S3KO4
    S3KO4 Member
    850
    could it be the sensor, as the oil temp wont read properly.
  36. superkarl
    9,468
    2,427
    Maybe you have a blockage somewhere, do an oil flush.
  37. superkarl
    9,468
    2,427
    But you said that it was rattly, as though there is oil starvation at the top end, so there must be an issue other than faulty sensor
  38. Welly
    10,696
    128
    Is the top end rattling like hell, and when you take the oil cap off, can you see oil splashing about?
  39. Welly
    10,696
    128
    Never mind, that answers my question....
  40. S3KO4
    S3KO4 Member
    850
    no rattling welly
