Oil pressure gauge fitting...
tezmanian devil Nov 20, 2011
  1. tezmanian devil
    tezmanian devil New Member
    24
    Evening guys and girls,
    I hoping to fit an oil pressure gauge to my 1.8t a3 but just wanted to know if il need anything to go ahead with it?
    All iv got is the gauge and the pressure sensor/sender thing, do I need anything to bolt it into the engine or is there somewhere I can bolt the sensor straight in?
    Also, where have people fitted there sensor?
    Any help would be marvellous!
    Thanks in advance :)
  2. beachbuggy
    beachbuggy Well-Known Member
    1,931
    201
    Top of the the oil filter housing there is a spare oil adapter socket. It should just screw into there. Should be an electric one so just need to feed a wire in to the cabin
  3. tezmanian devil
    24
    Cheers for the quick response dude, where's best to run my wire through, iv also got a boost gauge that I need to plum in aswel, is there any holes that I can poke through or do I need to drill and gromet my own hole?
  4. Lee172
    Lee172 GT3071
    430
    There should be some gromets on the bulkhead somewhere behind the airbox/filter. What oil pressure gauge did you get?
  5. <tuffty/>
    21,572
    4,045
    There is a grommet in the corner of the scuttle next to the pollen filter (passenger side) or you can drill holes in the cap (drivers side) where the loom enters the cabin...
