Oil Options?
READER84 Sep 18, 2013
  1. READER84
    READER84 Member
    247
    Had a warning light come up this morning saying my oil level was minimum, what oil should i get to fill her back up? Halfords suggests 5w30? Should i use semi or fully synthetic? What brands should i look at or avoid? Thanks
  2. READER84
    READER84 Member
    247
    54reg 2.0 tdi s-line by the way
  3. hades-
    9,482
    646
    do you know what oil is already in there ?
  4. READER84
    READER84 Member
    247
    Nope :(
  5. jwhat
    jwhat Member VCDS Map User
    541
    Fully synthetic that conforms to the Audi standard, Castrol, Mobil, Fuchs are what I use.
  6. READER84
    READER84 Member
    247
    5w30 Fully? Think ill go with castrol, is edge any better than normal?
  7. leeoliver86
    leeoliver86 New Member
    21
    I've always used castrol edge 5w30 in my audi
  8. sidibear
    sidibear Looking for Zombies !! Staff Member Moderator Audi A4
    2,320
    768
    Give Oilman a pm, he is the best knowledgeable one about oil on here.
  9. Molnboman
    Molnboman Well-Known Member
    1,338
    194
    You shouldn't mix your oil up Matey If you are unsure. If you have the service book and the last service was a VAG dealer....good chance it will be VAG long life...should maybe say in the service book. For the same price a full tank of derv you could treat your pride and joy to an oil and filter change and put in some nice fresh gear to be on the safe side.
    Good Luck
    A
