Oil on Ignition Coil
Maz Sep 15, 2013
  1. Maz
    Maz Moon is made of green cheese
    1,002
    10
    Hi all,
    decided to do the N249 bypass today which I managed with ease thanks to the various guides on the forum.
    Also managed to replace some perished hoses with some Forge items which was nice m easy.
    Coil packs were also going to be replaced with some red top versions but I noticed a little oil on Coil 2 as I pulled it out and Coil 3 was dripping in the stuff.
    Can any of you tell me why this has happened and what needs to be done to resolve it.
    Thanks.
  2. Lewis583
    956
    91
    The cam cover gasket comes in two parts.
    * One a long thin rubber ring which seals around he outer edge of the cam cover.
    *The other is a chain of rings which seals the cam cover around each of the spark plug/coil pack holes.
    It will be the chain of rings gasket which will have gone hard and no longer sealing. New cam cover gasket required bud. Both gaskets come as a pair.
    Link to eBay gasket
  3. Maz
    1,002
    10
    Thanks bud,
    I'll get on the phone to TPS tomorrow.
    One small job, turns in to another and another...
  4. Maz
    1,002
    10
    Do you think it is wise to replace the plugs as well?
  5. Lewis583
    956
    91
    Depends on how long they've been in there. I'd take the wet plugs out to clean the oil off them so if they haven't been changed in a while then you might as well tick another job off the list and fit new ones. :thumbsup:
