Oil low warning, oil is ok
@udi A3 Mar 6, 2013
  1. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,819
    197
    Ive had this before, now oil warning and then when checking the oil level was ok, so i started to ignore the warnings. A few weeks later the warning went on and i went to a garage to check the sensor, but on checking oil it was actually low.
    Last week i checked and topped up the oil, but not to the max as my topup bottle was depleated.
    Now the oil warning low keeps coming on randomly, but the oils half way between max and minimum.
    any ideas?
    Anyway to check senser with vcds?
  2. Broken Byzan
    13,237
    466
    red or yellow warning?
  3. @udi A3
    1,819
    197
    Yellow, minimum warning.
  4. Broken Byzan
    13,237
    466
    Faulty sensor then, cheap enough from memory and easy to fit
  5. @udi A3
    1,819
    197
    Hmm the mind boggles, 2 days ago I had oil today i dont!
    Just been out to check, oil is just above minimum and cold.
    fault code pulled:
    00562 sensore for oil level/temp (g266)
    27-10 - implausible signal - intermittent
    I dont think it should be on with oil above the min. How does the senser work? where abouts is it?
    Theres a lot of oil again at the back of the engine, time to start chasing leaks again.
  6. @udi A3
    1,819
    197
    £89.50 inc vat is not cheap as id like :(
  7. K04
    K04 Member
    57
    ebay dude
    Oil Level Sensor Sender for Audi A3 A4 VW Golf SEAT Skoda Octavia Eq: 1J0907660C | eBay
    unfortunatly when doing this you need to drop the oil it doesnt take more than 30 mins thought very easy its located on the bottom of your engine the oil sump and will have a wire coming out of it
    this is a picture of a sump the large hole you see is where the sender is located , also i might add is the fact its easy for the wire to come un done it happened to me on a speed ramp. worth a check before you order a new one
    check the large oil feed on the bottom of the sump not sure if its the same for dervs
