Oil Low warning not going out.
Chriscooke Apr 3, 2012
  1. Chriscooke
    Chriscooke Clueless!
    512
    25
    The oil warning light on my QTS has come on. I checked the oil level which did look a little low so I have topped it up.
    The problem being the light hasn't gone out. Do I have to reset this somehow or should it do it automatically?
    I've noticed that the dipstick top mount has also become brittle and broken. I doubt this is related though :(
  2. Broken Byzan
    13,237
    466
    what colour light is it?
    If its the level one, you'll need a new sender, it resides in the sump and requires the sump to be empty
  3. Chriscooke
    512
    25
    It's yellow and has "min" on it iirc. Sounds like a pain in the ass to sort :( Is it a sump off job or does the sender simply screw in to the side of the sump?
  4. aragorn
    18,608
    871
    It bolts in the bottom.
  5. Chriscooke
    512
    25
    Ahh thats not so bad then. Thank you :)
  6. Chriscooke
    512
    25
    Would VAGCOM pick up if the sensor has failed?
  7. aragorn
    18,608
    871
    unlikely.
  8. Chriscooke
    512
    25
  9. Broken Byzan
    13,237
    466
  10. Chriscooke
    512
    25
    Thanks guys :)
  11. murran
    murran Well-Known Member
    1,545
    39
    if that doesnt fix it, check the plugs where the engine loom goes into the car, under the ecu box cover on the o/s of the plenum chamber. the're at the back, for signs of corroded terminals/high resistance.
  12. ldoshiv2
    ldoshiv2 Member
    82
    happened to me 2 days ago mate, again mines seemed a little low, topped it up. mines never went out untill after 50 miles of driving. maybe give it a little time to see.....
  13. Chriscooke
    512
    25
    Cheers guys :) It'll be a while before I replace the sensor as I have spent enough on it this month already and my other car is taking priority at the moment.
    Hopefully mine does the same idoshiv2 :)
  14. Iceash
    Iceash Member
    391
    10
    Hi All, what true level should this come on? Also, it's not mentioned at all in the manual, slightly odd.
    Thanks everyone,
    Ash
  15. aragorn
    18,608
    871
    Dunno, but i've had main fairly low on the dipstick with no warning.
    I'd imagine it'll come on once it drops below "min" on the dipstick, which is about a litre short.
  16. Ste_Nova
    Ste_Nova Active Member
    1,223
    47
    also the bonnet switch has to be working to reset it
  17. Iceash
    Iceash Member
    391
    10
    Think that works as when I open it and shut it it clears the warning, just with full oil or near as damn it lol... From what I understand from the manual, the top of criss cross section in't max?
  18. aragorn
    18,608
    871
    Didnt know about the bonnet switch thing, my bonnet switch is missing, so its good to know if the light ever does come on!
