oil light flashing
daz616 Jul 20, 2010
  1. daz616
    daz616 Member
    37
    just noticed when i start the car the dash flashes with "oil" for about 30 seconds then goes off iv checked the oil and its spot on is this normal !
  2. ado66
    ado66 New Member
    29
    if its where the trip counter mileage is normally displayed then its just the service light, meaning its due an oil service.
  3. daz616
    daz616 Member
    37
    yeah its on the trip does it have to be reset by audi or is there a trick cheers
  4. ado66
    ado66 New Member
    29
    depends what year it is. early cars <1998 have to done with vag com or similar. as yours says "OIL" I guess it's the same as mine and can be done using the dash buttons.
    switch off ignition
    press trip reset button and hold it in, turn on ignition still holding it in. should now display "service OIL"
    pull out clock set button keep it held out until "service ---" is displayed
    press trip reset button again. should now display "service INSP"
    reset this the same way by pulling out the clock set button.
  5. aragorn
    18,677
    882
    Our old '96 also said "Oil" in the trip counter, and it needed vagcom to reset it.
    The new car comes up in the DIS and counts down, "Service 400miles" etc, not tried to reset that yet though.
