oil light dripping on ! oil level ok ??
AUDI@WRC May 5, 2008
  1. AUDI@WRC
    AUDI@WRC hows my driving call 0800-EAT-****
    84
    for the last couple of months my oil light has been coming on about once a week for a few seconds dripping on the screen ? i check the oil level every time but it remains fine ? i have changed the oil but it still comes on now and again ? my car is a a4 1.8t sport
  2. Siena
    Siena Active Member
    2,626
    Oil pressure warning is not an oil level indicator.
    It could be down to either of the following:
    1) Faulty oil pressure switch
    2) Dirty oil pick-up
    3) Worn / lazy oil pump
    Since it's irregular, I'd rule out the switch / switches being faulty.
    As for a dirty oil pick-up / sludge, I wouldn't even bother with flushing.
    The sump MUST be removed, to do a good job of cleaning the oil pick-up, and the sump. This is the first thing I'd do.
    If after re-assembly, and after fitting a new oil filter, and filling with fresh oil, the problem still persists, then I'd say you need a new oil pump.
  3. Broken Byzan
    13,237
    465
    TBH, one the sump is off to do the pick up, i would stick a pump in anyway due to the amount of work needed to get the sump off
  4. AUDI@WRC
    84
    what would you use to clean the sump and stainer ?
  5. AUDI@WRC
    84
    how much for a new oil pump ? also is there a strainer in there as well ? should i replace that as well ?
  6. Siena
    Siena Active Member
    2,626
    I clean sumps and all associated parts with diesel, never had anny issues.
  7. AUDI@WRC
    84
    diesel ? do you just spray on and rub with a wire brush ?
  8. Broken Byzan
    13,237
    465
    I bought a pump and strainer for under £70, then the sump gasket was £20 iirc. For me it bought peace of mind
  9. AUDI@WRC
    84
    where from ? also whats a iirc ? sorry for being thick as sh*t !
  10. Broken Byzan
    13,237
    465
    I got mine from my local motorfactor, If I Remember Correctly IIRC
