oil light a3 2004
djlazerblue Aug 26, 2012
  1. djlazerblue
    djlazerblue Member
    35
    had a leak from my oil switch replaced it, no more leaks, but the light comes on now and then flashing and beeping any ideas? cheers people
  2. SAiLO
    SAiLO Well-Known Member VCDS Map User
    1,078
    62
    What's an 'oil switch'?
  3. scotty0189
    scotty0189 Prepairing to Land
    72
    Do you mean the Oil level sensor?
    Common for them to go - mine just has.
  4. djlazerblue
    djlazerblue Member
    35
    oil pressure switch, i changed it but the ight still comes on and beeps
  5. Geraldy212
    Geraldy212 Sportback owner
    565
    42
    Carefully check the contacts connector and wiring loom. Or change the switch for another one. Or ask a garage to check if your oil pump is generating sufficient pressure. Since you have recently touched the wiring loom, I would suspect that first.
  6. djlazerblue
    djlazerblue Member
    35
    yeh i was gana try another switch, oil level seems fine, could be a faulty one, cheers for you input mate
