Oil level Sensor & N75
phil08 Jan 7, 2014
  1. phil08
    phil08 Member
    97
    Hi all,
    Took my 2000 S3 to a local VAG specialist today as I had an amber oil sensor light come on.
    Turns out the oil level sensor has died so a new one needs to be fitted.
    When the diagnostics were plugged in it also threw up a dodgy N75 and they have suggested again a replacement having checked all the hoses.
    My question is where is the best place to buy these parts?
    I'm not after oem per say but a good quality part none the less.
  2. Vex182
    Vex182 Guess what I drive...
    1,035
    79
    I would stick with OEM for both them, you will only have to change them sooner if you buy non genuine. A genuine N75 can be purchased from eBay easily, make sure it's brand new and the correct code.
  3. Nilz
    11,318
    870
    I got my Oil Level Sensor from Euro Car Parts, was about £47, its a genuine one, but just had the make filed off.
    The N75 was from TPS, cant remember the price, but wasnt that expensive to be honest.
  4. Vex182
    1,035
    79
  5. phil08
    phil08 Member
    97
    Thanka guys will give that a look. Ideally want the car to be running spot on so I can have it mapped eventually.
  6. phil08
    phil08 Member
    97
    Does anyone happen to know the correct codes for a 2000 S3 APY oil level sensor and N75 valve?
    Apparently there are two very similar for the oil sensor but I can't check as I have no access to get under the car
  7. phil08
    phil08 Member
    97
    Is anyone able to help or advise me as to how I can work which specific part numbers I need?
