oil leak from turbo pipe
john24susan Feb 26, 2008
  1. john24susan
    john24susan Member
    33
    Hi All, I own a Audi A3 sportsback 2005 TDI 140 bhp with 50,000 miles on the clock and have found droplets of oil on my runway . I have had the car on the ramps and removed the bottom cover and it seem to be coming out of the hose going into the cooler. I removed the pipe and have a small amout of oil from the pipe. I also removed hose from the other side of the cooler and notice a small drop of oil as well . I have run the car for 2weeks and the oil leak from the outlet pipe has started to weep oil again !
    I wonder if anyone has the same problem ?
    Can the cooler be cleaned out in situ or must it be taken out to clean it and if so what with ie cleaning fluid.
    Many thanks John.
    :think:
  2. consilio
    consilio Up the owls!
    666
    wish I had a runway! :respekt:
  3. Boydie
    Boydie Guest
    This is common and ok as long as it is not gushing!
    My car does this and seems fine - just keep up to date with the oil changes/top ups!
    Is it on the passenger side, just where the pipe goes into the intercooler and there is lots of oil goop on the undertray??
    I just cleaned mine off with "gunk" degreaser - you can get this from halfrauds!
  4. Gti Jazz Blue
    Gti Jazz Blue Active Member VCDS Map User
    1,655
    I had a similar leak sorted out under warranty.
    Not entirely sure what they replaced but the issue was with the joints.
    Paul
