oil leak and oil/filter change
scott13 Feb 21, 2011
  1. scott13
    scott13 Member
    77
    have discovered a leak from the oil filter area do you think this is likely to just be a bad seal in the filter?.. also i want to do a oil/filter change but have never done this before, do you guys think this is an easy job for a novice?
    cheers
    Scott
  2. hades-
    9,482
    646
    very easy
    and theres a few guides around
  3. scott13
    scott13 Member
    77
    yes mate i know how to do it just never been brave enough to attempt it ;)
  4. sportstractor
    sportstractor Chugger
    2,709
    yep its one of the easiest job you can do, just a bit messy the first time
  5. scott13
    scott13 Member
    77
    the bit that bothers me most is jacking the car up and putting on axle stands...
  6. talentwalsh
    talentwalsh Member
    139
    Try and get someone with a pit, ramps or a lift if you can, audis are pretty low slung cars and even with a jack and stands its pretty tight under there!! It is on my S3 anyway. It will make your life a whole load easier!!
  7. scott13
    scott13 Member
    77
    nyone with any of those..so is it to hard just to do it on axle stands?
  8. a3tdi2001
    a3tdi2001 Member
    437
    A pavement kerb for one side and a breeze block for each of the other two wheels with two bricks to get up on the blocks, cheap from B&Q:)
  9. Dani_B19
    9,381
    403
    Oil change, pikey style :), lmao.
  10. a3tdi2001
    a3tdi2001 Member
    437
    Hey don't knock it. Easier than arsing about with axle stands and a jack. Beware though, there is ALWAYS an old neighbor who comes up to ask you what your doing:)
  11. rossbrownlee
    rossbrownlee Ross_S4
    719
    Go for it mate. get wired in there.
    everyone has to start somewhere and that is one of the easier jobs to do......IF it all goes well... ;)
    From your profile pic your drive looks pretty steep, maybe want to use the road or somewhere level for stability when it is jacked up. or you could get a set of ramps pretty cheap out of halfords.
    Top tip - Get yourself a kitchen washing up basin (don't nick it off your mam / missus!) and use that to catch the oil draining from the sump plug. nice big opening to catch it all in and you can decant into a drain bottle or whatever later for disposal.
