OIL FROM ALL BOOST PIPES
RGC Aug 21, 2008
  1. RGC
    RGC I void warranties"!
    149
    Hi all,,,
    just pulled the bumper of my a3 to see quite a few oil leaks from just about every boost pipe join,
    is this normal??
    see pictures below
    thanks
  2. RobinA3
    RobinA3 Well-Known Member
    1,827
    47
    That shouldn't like that, looks like the engine is pulling over a lot of oil.
    whats your oil consumption like?
  3. Boydie
    Boydie Guest
    I cannot see the pics but afaik it is common enough but going by robin's response you might have an excessive amount
    the boosts pipes/intercooler pipes need to breath so will spit some oil residue - you would usually find this at the front passenger side inbehind the fog light
    When I had my MOT I took off the underside sump tray and it was caked in oil and muck after 4 years of driving so just cleaned it
  4. RGC
    149
    looks to me like its been doing it for some time now judging by the amount of **** stuck to the belly pan plastics,
    it runs fine with no smoke
    i have only owned the car for a few weeks now so cant tell the oil usage?
  5. DeckedS3
    DeckedS3 Well-Known Member
    868
    298
    IMO that isn't that bad.... What kind of mileage has the car done? Is it chipped or running higher boost than normal?
    Do you drive it hard? I wouldn't be too worried.
  6. RGC
    149
    its done just over 75k :racer:
  7. The911SC
    The911SC Active Member
    1,032
    It looks more like residue than fresh leaking oil to me and a build up over many miles.
    I would probably (carfully) jet wash it off with engine cleaner applied and keep an eye out .
    Guess it could be slight vapour leak over many miles with oil haze?..
  8. ScottTDI
    ScottTDI Member
    88
    15
    Mine has done the same amount of miles and the belly pan and lower intercooler pipes look in the same condition.
    I just cleaned them off, however I did disconected the boost pipes and no oil dripped out.
  9. JST_A3
    JST_A3 Member
    99
    It looks normal for that kind of mileage. I had a Golf with the 1.9 TDI engine and it was similar. I would check the joint in the second from last picture though, it doesn't look straight to me and could be coming loose.
    As the other posters have said, clean it off, it's then easier to keep an eye on to see if there are any fresh leaks.
    At that mileage you would probably benefit from cleaning the EGR valve, there was a recent thread on this: help on 2.0TDI engine
  10. RGC
    149
    Thanks Guys :respekt:
  11. The911SC
    1,032
    They dont caal 'em oil burners for nothing you know! :box:
