Oil filter location?
Mattyst Jan 3, 2013
  1. Mattyst
    Mattyst New Member
    Hi all,
    Quick question, can anyone tell me where the oil filter is located on the 1.6tdi A1 Sportback (2012).
  2. gen.heinz guderian
    gen.heinz guderian Well-Known Member
    1,346
    125
    Have a look in your handbook.
    Sure someone more knowledgeable than me will be along to give you a definitive answer.
  3. FactionOne
    FactionOne Administrator Staff Member Administrator
    3,272
    183
    Here's an image from Audi, apparently of a 1.6TDI as fitted to the A1 Sportback (I would imagine largely the same throughout the range).
    As you look at it, you can see a fairly featureless shiny box pretty much slap-bang in the middle of the image (due east of the alternator). As far as I can work out, that's the oil cooler, which is attached to the base of the filter bracket - certainly there's a cylindrical unit visible behind it, which I'd suggest is a good candidate for being the filter bracket. It should just unscrew at the top, allowing you to pull the filter insert out (of course with a suitable amount of swearing due to it being the insert type, and drenched in oil! ;)).
    Hope that's useful; all the best,
    Rob.
