AARON77
Woke up this at 5 morning to a nice lil puddle under the car
Checked the water reservoir and that was empty! Not so bad as it was str8 bak to bed for a few hours
Anyway this is what I found in the day light
Oil cooler pipes had corroded so much that water had escaped
Was an easy fix tho, just had to take off a a few pipes and the throttle body so I could get to oil cooler.
Then just popped off the two pipes and sanded all the corrosion off the alloy pipes attached to the cooler.
before
After
Was just a case of putting it all back together
before
After
