OIL CONSUMPTION
Discussion in 'A4/A4 cabriolet/S4 forum(B6 chassis)' started by JohnBoy, Nov 8, 2005.
  1. JohnBoy
    JohnBoy Member
    Jan 28, 2004
    85
    <font color="blue">I have a 2L petrol multitronic with 50k on the clock. I have to put a litre of oil in every 15000 miles. Never had to do this on any previous car, at least not at such a rate. The dealership told me this was normal /ubbthreads/images/graemlins/shocked.gif Can anyone vouch for this? </font>
  2. Advert Guest Advertisement
  3. jim1965
    jim1965 New Member
    Aug 4, 2005
    23
    that's not too bad johnboy, did you mean 1500 miles though? - my 2.0l petrol uses approx a litre ever 2-3k miles - the manual says anything up to a litre/1000k
  4. CJ A4
    CJ A4 Active Member
    Nov 28, 2004
    2,664
    Yep on my 2.0 i'm putting about 2 litres in every 2 months or about every 2500 miles
  5. JohnBoy
    JohnBoy Member
    Jan 28, 2004
    85
    WHY? I have never experienced this huge oil consumption in any other car Ive owned. Where does it go? and why is the Audi engine so oil hungry?
  6. That's about right around a litre per 1000miles is within tolerance for most manufactures these days.
    So a litre every 15000 is pretty good.
  7. JohnBoy
    JohnBoy Member
    Jan 28, 2004
    85
    Yes sorry I did mean 1500 miles not 15000.
    But I go back to my original question Why is it so high?
  8. Similar situation here, I'm adding 1 litre of 10w-40 synthetic oil every 1,000 miles to my A4 97 2.8 Quattro (75K). I haven't experienced this with any other car either and am also curious if someone can answer why oil is being used up at such a rate? This should not be the norm surely! My previous A4 96 2.6 Quattro (95k) never lost any oil.
    The Audi Technician has checked the car over and there's no sign of any external oil leaks and the exhaust is not smoking like it's burning oil. He says it may be an internal oil leak - perhaps that explains why our beloved Audis are loosing oil!
    Strange /ubbthreads/images/graemlins/confused.gif
  9. JohnBoy
    JohnBoy Member
    Jan 28, 2004
    85
    Mine does not burn or drop it either. There must be some technowhizzkid out there that can enlighten us or do we all just accept it as normal in an Audi?
    Vorsprung durch Öl perhaps? /ubbthreads/images/graemlins/smile.gif
  10. Some reports suggest that they burn more oil if you baby then engine during break-in. I drove mine normally (after driving gently during warm up) and it's used about 1.25ltr in almost 9k miles.
    I've read of some using 1ltr / 1k miles.
  11. The911SC
    The911SC Active Member
    Sep 28, 2003
    1,035
    My 1.8T doesnt use ANY - neither did my last 1.8 T but whilst driving to Gatwick airport last Sunday for a flight to the U.S, the Oil level warning light came on on the S4. Bit worrying, stopped, topped up, took about 3/4 litre but seems the V8 uses oil also?
  12. JohnBoy
    JohnBoy Member
    Jan 28, 2004
    85
    Strange isnt it? Normally if an engine uses oil at the rate of a litre per 1000 miles you get tell tale clues ie drips on the drive or smoking exhaust when excellerating... Where the hell does it go?
  13. GSCollie
    GSCollie Member
    Nov 20, 2004
    165
    Yep, I've used about three quarts of oil in the first 18000, V8's do drink it. It also takes 9 litres at service which is why the service price is steep, equates to about £100 of oil.
  14. jim1965
    jim1965 New Member
    Aug 4, 2005
    23
    and the other thing is the cost of the Longlife oil too - just used £40 worth on DIY lub and the computer defaulted to standard from variable when reset carried out - it's std oil for me from now on, at least the cost of constant top up is reduced. besides, it seems like a lot of bother for not that many more miles
    also, could the consumption have anything to do with the Longlife oil itself - i wonder how i'll get on with run of the mill oil after next service - 7500k to go /ubbthreads/images/graemlins/wink.gif
  15. brixo
    brixo Member
    Feb 5, 2004
    79
    When I was looking for a B5 shape A4, I was told to keep well away from the 2.0 petrol engines - by the Audi saleswoman.
    Apparently they are known to use a little more oil than usual or expected. In her words "more oil than petrol". I believe they were worse in the A6, such a small engine for a large car.
    I believe Audi dropped that particular engine type after a short while. But this is what a main Audi stealer saleswoman told me... So, I could be wrong, very wrong.
    With my old shed of a 1998R 1.8T Sport, ECU remapped and 127,000 miles on the clock, never required a top up. Yet my 2003 1.9TDi 130 required 1/2 litre of longlife after 8000 miles from a recent service!
