Oil consumption TFSI
Ads Jul 25, 2010
  1. Ads
    Ads License to drive
    8,230
    608
    Read a few threads here and elsewhere about oil consumption on the TFSI engines, but mileage per litre had quite a range.
    Mine is a 2.0 TFSI and seems to be using a hell of a lot compared to any other car I've owned.
    I reckon I've gone through a litre in about 2,500 miles / 4 months.
    There are no leaks as far as I can see, I think it's just getting used.
    Interested to hear what other's consumption is like.
  2. NHN
    29,413
    1,740
    They say litre per thousand miles, so I'd say thats fair.
  3. Ads
    8,230
    608
    Hello mate...
    That much oil as quickly as that?! Wow.
    Ok, i'm doing a little better then I guess.
    Nipper not here yet??
  4. S.
    S. Save the manuals Team Ibis TFSI Owners Group Audi S3 quattro Manual
    2,027
    553
    mine did 0.5l in 9000 miles. i guess that depends from engine to engine.
    my old car (2.0) did 1.0l in about 1000 miles.
  5. antmax7
    antmax7 Member
    295
    my 2.0t a3 has never used any in the 10k before it was serviced and it has used none in the 1500 miles after the service either
  6. JamesBaby
    JamesBaby Member
    44
    15
    You have got to be kidding mate. Who on earth told you that?. If a car burned that much oil there is desperately something wrong with it.
    I find that after an oil change, one sometimes needs to top up oil after a few thousand miles. But after that 'top up', it should be pretty stable.
  7. Jo Sharp
    Jo Sharp Member
    131
    Audi will say that anything up to about 1L oil per 1000 miles is OK.
    My 2.0 TFSI and now my S3 use hardly any (1L per 10 000 miles). I put it down to giving the engine a proper run-in to bed the oil rings...i.e. really loading the engine from low revs in 3rd gear when very new.
    If you are having problems with oil consumption, try giving it a really hard thrashing.
  8. VWAddict
    VWAddict Member VCDS Map User
    656
    9
    ********! :jester:
    Read up on it. VW and Audi classify the threshold of 'excessive' at 1 bottle every 800 miles.
    My Audi uses a quart bottle (near enough to a litre) of oil every 2000 miles or so.
    My MkIV VW is also a 2.0, and it uses a bottle every 1200 miles or so. Been that way for 170,000 miles.
    My Porsche sips oil also; about every 1500 miles it polishes off a bottle, but then it too is a turbo. 240,000 miles on, and still everything's fine... it just drinks a little oil.
    This has been a known thing with some of VW's and Audi's engines for over a decade now.
    Since I'm in the habit of checking oil on ALL of my cars at every petrol fill-up, this is not really a problem, but for people who think that there's no need to check the oil level between changes, they get a SERIOUS shock when the light comes on! :mad:
    Keith
  9. Ads
    8,230
    608
    Thanks guys, very helpful.
    So a litre per 2.5k miles is pretty much normal then.
    When I went along to my local Audi dealer to buy some oil for topping up they did say the tfsi burns a fair amount of oil, just didn't realise it would be this much.
    My old fsi didn't burn a drop in one year/8k miles.
  10. a3_dan
    a3_dan Member
    588
    Sounds about the same as mine mate. I don't use Audi oil when topping up though, I use Castrol.
  11. Ads
    8,230
    608
    I think the oil that Audi supply is castrol. Or at least that's what they gave me when I went to buy a top up.... i think.
    Cost about £11 a litre.
  12. JamesBaby
    JamesBaby Member
    44
    15
    Known?, perhaps to some degree, but not common. I knew the Diesal's burned a bit but not 1lt per 1k.
    If it's true it must be specific engines then. My first VAG car back in 97, was a 95 Golf Gti, and since then I have had succesive VAG cars including Golfs petrol and diesal and my current S3. Never once have I had to put more than little top up during those 13 years of driving. On top of this many of my friends have VAG cars of varying engines and have done for many years, and not one has ever mentioned anything about putting oil in to such a degree.
    My S3 was supplied from Audi after its service with Mobil 1 which is not cheap to buy. It would add considerable cost due to the 16k I do a year. If it ever starts burning 1lit per 1k, it's getting sold.
  13. FranA3
    FranA3 FMDETAILING Regional Rep Site Sponsor Gold Supporter Audi A3 Team Brill Red
    7,237
    332
    its the same with bmw's too they use oil like crazy but my 1.6fsi doesnt must be the tfsi engine that used oil but its not the same for every car every car is different it all depends i suppose on mileage per year how they get driven etc.. etc...
  14. Scott
    Scott Well-Known Member
    1,306
    126
    I've managed 17,200 miles topping up 1 litre. 2.0 tdi CR
  15. NHN
    29,413
    1,740
    Yeah its Edge now, also known as SLX 2
    Dealer is actually a fair whack cheaper than Halfords aswell.
  16. NHN
    29,413
    1,740
    I'd agree with that statement.
  17. PH1L
    PH1L Gievf Buckets
    3,851
    40
    try giving the engine a flush an using synthetic oil of a higher grade than the std
  18. Ads
    8,230
    608
    Remind me.... Castrol Edge 5w-30 for the TFSI, right???
    Need to buy some but might not be able to get down to Audi.
  19. NHN
    29,413
    1,740
    You would need to check the viscosity for your engine mate, I'm not sure if TFSI shares the same weight, although it shares one thing, the high fecking price.
  20. Ads
    8,230
    608
    Haha. I thought I could get away with being lazy. I'll go check now.... :3sadwalk:
  21. Ads
    8,230
    608
    Just been down to audi and bought some oil. Castrol SLX III.... £16 for 1 litre.... or £41 for 5 litres. No brainer really. But I bought the 1 litre :faint:
  22. S3Alex
    10,802
    4,805
    Mine seems to use well under the litre per thousand miles limit,and usually seems to be about 1 litre every 5-10 000 miles.
  23. NHN
    29,413
    1,740
    Looks like you got Castrated, I can buy that stuff from Audi for £8-9 a litre
  24. Ads
    8,230
    608
    That must be a price special to you though??
    Cheap as chips!
  25. NHN
    29,413
    1,740
    Yeah, thats cause I'm very very special in my own little way, lmfao
    Actually spending thousands there over the years helps. :)
  26. Ads
    8,230
    608
    Lol. Special needs!
  27. NHN
    29,413
    1,740
    Yes I need something special
  28. Ads
    8,230
    608
    Well mate you don't have long to wait. You've got a special delivery on its way, with very very special cargo!
  29. NHN
    29,413
    1,740
    This is true & the cargo I will probably see many times a day lmfao, I'm searching ebay for WW2 gas masks, anyone wanna donate there's.
  30. Sally, Surrey
    Sally, Surrey New Member
    Yep, about right. My A3 cab drinks about a litre for every 1500 miles. Should get better with age hopefully?
