Oil consumption on 2011 S3?
Fritz-s3 Dec 26, 2013
  1. Fritz-s3
    Fritz-s3 New Member
    23
    Been doing some research as i'm knew to the audi scene and read that the 2.0 tfsi is prone to consuming oil. After reading this thought I should check mine and oil level half way between low and full. My S3 is on longlife service so had oil change a year ago so probably not too bad but my previous tuned focus RS never used any. What causes these engines to consume oil? Would an uprated PCV improve things? How much is oil for the S3 from audi?
  2. RobbieWebs
    RobbieWebs Well-Known Member VCDS Map User
    1,031
    249
    I think it's quite expensive from audi bud. They sell it in 1l bottles I think.
    Some buy oil from TPS etc as it's much cheaper.
  3. gen.heinz guderian
    gen.heinz guderian Well-Known Member
    1,346
    126
    If you buy a drum from TPS it woks out roughly £2.30 a litre
  4. RPB
    RPB Active Member Team Ibis Audi S3 Black Edition DSG
    401
    70
    Thats not using oil if its only halfway after a year! lol. I can see why you would think it is though if your old Ford didn't use any at all.
    My 2011 S3 has used 0.4 litres in 5k miles since June when it had its last service.
    EDIT: edited to ask you, do you not check fluids and tyres every week? This is something I am very anal about. I always check fluids and tyres once per week without fail. I can't believe a lot of ppl don't even bother looking until a bloody light comes on the dash!
  5. JoeS3
    JoeS3 Member
    105
    but doesnt the car constantly check the oil levels itself?
    i.e. that oil service indicator. or am i getting it wrong.
  6. JJ.Foulds
    JJ.Foulds Well-Known Member
    1,263
    176
    iv never checked either oil or tyres since owning the car in july :/
    Im a bad man.
  7. S3Alex
    10,852
    4,839
    I'd avoid the long life service schedule,or at least have the oil changed maybe half way through the intervals.
    I did it once,and the stuff that comes out at the end of an interval is pretty nasty.
    One problem is that some eat oil,and others barely sip it,and you don't know until you've got one or the other,although the PCV system is another issue altogether,as it feeds oil vapour and rubbish back into the inlet,and can lead to the intake valves coking up.
    If you intend to tune it at all,it's worth getting a catch can system fitted.
  8. Fritz-s3
    Fritz-s3 New Member
    23
    Only owned car for about a month and the car had audi health check before i picked it up and everything was fine then. Doesn't appear to have used much but will religiously check it like yourself from now on after doing some research on oil consumption.
    Think i'll get it serviced before indicator because it's still showing another 8k miles until service which would be about a year and a half since last oil change.
    Read that the 2.0 tfsi suffers from oil consumption, is S3 engine the same or does it have different pistons etc?
  9. crunchie
    crunchie Active Member
    880
    77
    Mine gets serviced at Audi using long life oil but I get it done every 6/7k.
    I wouldn't buy a car that has been on long life services.
    Mine is on 30k now and I've never had to top up between changes.
    My MK4 Golf GTI 2.0 8v however uses around a 1l every 1000 miles lol.
