Oil catch tank/can..
Lee Goodall Oct 19, 2009
  1. Lee Goodall
    Lee Goodall Active Member
    2,279
    Can anybody recommend an oil catch can?
    Any info would be greatly received.
  2. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,776
    33
    A guy over on AudiSRS made one himself out of some basic plumbing parts from B&Q. Works better than a couple of the branded items which he'd tried previously.
  3. Lee Goodall
    2,279
    Nice one.. cheers mate.
  4. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    I am making mine. stainless thermos flask...
    pretty easy, key thing is to make sure the contains has a good amount of material in it, wire wool, lathe swarf etc.
    are you planning on venting to atmosphere or back into inlet?
    I need to tap the cam cover on mine, some already have it.
  5. Lee Goodall
    2,279
    Originally I was planning on just venting to atmosphere but don't know whether I could put up with the warm oily smell for long.
    I have also heard of others having running issues if the vented air doesn't recirculate into the system?
  6. Broken Byzan
    13,237
    465
    be hard core, run a pipe to the floor,lol I did that with my Very old Mk2 ecsort,lol
    Should have seen the undserside of the car when i blew the engine, how it rusted through all that oil, i will never know
  7. Lee Goodall
    2,279
    LOL..
    I had a MK1 Polo with a breather filter on and the smell was strong.. might give the A4 that racer feel though lol.
  8. jcb
    4,132
    13
    yeah, it does stink. it also affects some of the pressure sensors or vacuum sources. not sure which or where but it would make sense.
  9. Broken Byzan
    13,237
    465
    Not oil pressure, vacuum for sure as that relys on it being a sealed system with non return valves in place etc
  10. Matt82
    Matt82 Active Member
    2,365
    the underside is about the only part of my golf that i dont worry about rust now :icon_thumright:
  11. docurley
    4,071
    86
  12. Lee Goodall
    2,279
    Cheers docurley :icon_thumright:
  13. gaz71
    gaz71 1.8T Quattro Sport AJL
    286
  14. jcb
    4,132
    13
    interesting but IMO not big enough.
    ideally you want a much larger volume around 500cc / half a litre with plenty of air between the condenser material internally.
    the vapour entering needs plenty of space to condense and remove the max amount of liquid (oil and water) before re-entering the inlet tract.
    The larger volume creates a pressures drop, cooling and slowing the vapour down.
    that petrol filter will collect some but nothing like the amount it should be collecting.
