Oil Catch Can mini group buy anyone? including PCV system simplification.
OllieH Mar 3, 2010
  1. Westy
    Westy Well-Known Member
    17,443
    1,105
    I dont suppose you have the part number handy Tim?
  2. 1animal1
    9,978
    na sorry mate, go and have a look for my last 2 or 3 threads in stoke audi section, they are defo in there with prices
  3. Westy
    17,443
    1,105
    I couldn't find it mate but I'm sure my local stealer will be able to pick it out for me. I'll post up the number one I know it for anyone else who might want to order one.
  4. 1animal1
    9,978
    no worries doood, id go searching for ya but my works browser wont let me search or view anything but the S3 section
    best bet is asking Stoke, with postage they are still wey cheaper than the local main dealers and GSF/Euro
  5. Westy
    17,443
    1,105
    Just picked one up from Hatfield Audi for £24.03!!!!!!!!! As they had it in stock and I want it sorted ASAP I thought what the hell.
    Anyway the part number is 06A 129 101 D and it is called a "Pressure Relief Valve" on ETKA
  6. OllieH
    OllieH Member
    368
    Sorry for the slow reply. Yeh, hockey puck was a b**ch to fit into the TIP. Had to file down the raised lip before it would even go into the hole, plus a bit of lube. Even then it kept wanting to pop out which is why I had to jubilee it in. Sorry, thought I'd mentioned this when writing the guide :redface:.
    Would imagine the fault codes are caused by what you said. I had a couple come up when I originally removed the PCV pipework as I removed the inlet manifold and sensors to do it. Where did you mount yours in the end?
  7. Westy
    17,443
    1,105
    I mounted my can in the exact same place as yours and followed your guide to the letter so thatnks again for that.
    I tried for around 45 mins to get that puck into the tip! I filed down the lip then ended up actually hacksawing the end off because I'd made it too rough with the filing and it was damaging the silicone. I had to trim off the damaged piece of silicone from the TIP and couldn't afford any more mistakes or i'd have to buy another TIP!!!
    Anyway my 19mm to 16mm reducer should turn up today and i'll try and get it fitted tonight with my new puck valve, I think this will be sorted then and it might be worth a mention in your guide for anyone else doing this as it nearly reduced me to tears :(
    Do you think that it will cause any problems with the puck valve sitting on a few mm reduction on the breather system?
  8. OllieH
    OllieH Member
    368
    I would imagine you'll be fine. I've read of other people doing this with 19/16mm reducers on the catch cans because they couldn't get a can with 19mm connections, and they seem to have no problems.
  9. Westy
    17,443
    1,105
    Well the reducer turned up last night and I cant get it to fit into our new 19mm oil hose! :banghead:
    I'm now going to have to try and file/dremmel the lips on the reducer down to get it to fit inside the hose. The 16mm end is spot on though and fits snuggly inside the oil hose so I expect it to slide into the TIP with no trouble.
  10. Westy
    17,443
    1,105
    Ok got the reducer to fit in the end. Took tip all the way off then used a bowl of boiling water to soak the pipe so it was soft enough to get the reducer in. The airbox was a bit of a squeeze to get back in but it's all sorted now.
  11. s3tle
    s3tle Member
    239
    Hey guys, just read through this as i think i'm gonna install a catch tank and delete the VAC as mine are failing
    I was wondering how it's working out for those who did the install and if they have had any problems after installing/deleting
  12. Dani_B19
    9,343
    394
    Installed mine about a year ago and it's running fine, although i reused some of the original rubber hoses and they ended up failing and causing me some right headaches.
  13. thorsy22
    thorsy22 Member
    308
    How often are having to empty it dani?
  14. s3tle
    s3tle Member
    239
    As OllieH orginally said 19mm inlet tanks aren't easy to find in the UK, having spent a few hours looking i agree!!
    So looks like i'm gonna get one from the US, is there anyone else who is interested in doing this? i could order a few and save on the shipping?
    Would be just the tanks as the other bits are easy to find over here and Ollie has done all the hard working
    Looking at these tanks
    the orginal
    Unknown Location....Scary!!!
    a nice stealthy one!!
    Stealth Oil Catch Can
    and a complete kit, but the recirculated version not shown in the picture, DubTek stock the shown vented one in the UK
    BSH 1.8T Catch Can Kits - BSH Speedshop
  15. Dani_B19
    9,343
    394
    Havent had to empty it yet!
    I'm up for another oil catch can, mine was only temproray, im wanting one like the guys of here have bought.
  16. thorsy22
    thorsy22 Member
    308
  17. s3tle
    s3tle Member
    239
    cool, i emailed saikou michi last night for a price of 3 delivered so we'll see what they can do, sadly the price shown on the website has gone up $10 since the first group buy
    The BSH ones have a dip stick so you can check the level, and lots have a clear tube on the side, but importantly we need 19mm ports.
    That hosequip kit on ebay should have the correct parts we'd need
  18. Dani_B19
    9,343
    394
    Well im running a toyosport one and it has a clear tube on the side to see what the level of oil etc is at. The toyosport one also has 16mm outlets but what i did was use some 16mm tubing to sleave the outlets then just attached 19mm other the top of that.
    Be interesting to see what price the saikou will be.
  19. 1animal1
    9,978
    yeah count me in on this, i can 100% vouch for the quality after having one for the A3 on Ollie's GB....still empty after few months fitting.... still got the hoses left over too, enough to do mine ;)
  20. thorsy22
    thorsy22 Member
    308
    Not many black catch cans with 19mm inlets/outlets, most are alloy/chrome or shiny colours :-(
    I like the look of the Saikou Michi and the stealth 42 draft design, the quick drain plug on the 42 stealth would make emptying nice and easy compared to the Saikou Michi.
  21. s3tle
    s3tle Member
    239
    yeah i think the Saikou Michi and the stealth 42 draft design seem the best, i actually prefer the Stealth 42 one, because of the 'stealther' looks, side ports and crackle finish to match S3 engine covers etc. But that said the Michi is tried and tested on here so that is of course good!!
    I'll post up the replies from suppliers when i get them, wanna get them ordered in the next couple of days.
  22. Dani_B19
    9,343
    394
    Well depending on price i'll be in, if its daft money im out, got more important things on at the moment.
  23. s3tle
    s3tle Member
    239
    yeah i know it's gonna come down to the price, hoping it should about be same as OllieH got them for £60-70
  24. Westy
    17,443
    1,105
    Mines still going strong and not had anything to empty yet either. The only thing I would like on my can is an easier way to access the drain plug as it is a bit of a squeeze.
  25. S3 TAM
    S3 TAM Pocket now empty
    624
    10
    If its not to late count me in.
    I was looking at the mk4 golf one on the bay for £119
  26. s3tle
    s3tle Member
    239
    ok Design Draft have come in with roughly £75 each with 3 units delivered to me (roughly as excahnges rate vary etc..) so a bit more than the Michi's before, but haven't heard back from them yet.
    If Michi says £60 each then i'd say we should go with their 951, but if they are about the same i think the Design draft is a better design for a 'oem' look.
    Either way should be a liitle cheaper than the BSH's off ebay, say about £110 all in with pipes, angles, clips etc...
  27. s3tle
    s3tle Member
    239
    Thanks Westle for the feedback, the DD42 Stealth one comes with a side plug which you can fit a tap and pipe to, so you could run the pipe to somewhere easy to access
  28. OllieH
    OllieH Member
    368
    I think you'll find the Saikoumichi's will be about the same price as the Design Draft ones. The only reason I got the Saikou's so cheap last time was because I kept emailing them back with more numbers on the group buy, and kept knocking them down. Either way, its definately worth getting.
  29. thorsy22
    thorsy22 Member
    308
    I like these ones better as the drain plug is on the side so its easy to get to, and as said can buy/fit a tap too, with a drain pipe installed somewhere nice and accessable for easy emptying!
    S3tle appreciate the hard work, dont know if its worth asking for a quote on the quick drain plug for the DD42 if going that route?
  30. s3tle
    s3tle Member
    239
    Thanks Ollie, yep i don't think there be much difference, thanks for this thread in the first place!!
    @Thorsy22, i also think the DD42 are better!! just the quick drain plug should be £5.20, and the drain plug kit would be £8.20, i think it would still be best to get any other piping from the UK as it heavy to post? although it i cheaper from them, etc...
    Hopefully the other suppliers will reply soon so we can check there aren't any bargains to be had!!
  31. thorsy22
    thorsy22 Member
    308
    So approx £80 for can and the quick drain plug if going DD42 route.
    Think would be better to get the drain hose from over here. Found some on the bay for £3.20 a metre delivered Oil return hose 3/8" 10mm R6 hot oil hose on eBay (end time 28-Aug-10 13:14:00 BST)
    £20 quid for the 19mm hose and connections from the bay (see previous post), reckon £105-£110 like S3tle said earlier. Not too bad at all really.
    Edit: the 19mm kit is £27 delivered, forgot the delivery cost :blush:
  32. s3tle
    s3tle Member
    239
    Mr Saikou has replied this morning, so using paypal for conversion, as that's how'd we'd pay
    Three Saikou Michi 951's delivered to me would be $300 = £199.91 so £66.64 each
    Three DD42 Stealth's to me would be $357.27 = £238.07 so £79.36 each + quick drain plug if we want one -- bit more than i had originally thought as i had't used paypals exchange rate :-(
    So what do you think?
    another consideration is import duty.... i don't think OllieH got charged any for the original batch of 951's, not sure if a order from DD42 would be flagged up as they are 'more' of a company, invoicing with package etc...
  33. s3tle
    s3tle Member
    239
    ok just scanned through the thread, Ollie got charged £15 duty on the first batch, which actually seems quite low, i'd guess there wasn't an invoice in the package so customs estimated the value.
    Duty rate is 4.5%. Vat rate is 17.5% dependant on amount you have to pay both.
    i've put the figures into a online calulator to see what we might have to pay
    for the Saikou Michi, basically an extra £34 total for VAT if customs value correctly
    Import duty rate for oil tank is 4.5%
    For DD42, we'd pay both VAT and Import duy total £55
    Based on that i'm thinking the Saikou Michi ones might be safer! and i'll ask Mr Saikou to not put any invoice in the package!!
  34. s3tle
    s3tle Member
    239
    saikou michi is best case £66 worst £77!!
    DD42 best case £79 worst £97!!
    It tricky because OllieH can't of got charged the correct customs, but i guess customs didn't value some metal cans at £66 each!!
    I think we should go with saikou michi and remove any invoicing etc!! if there are more than 3 we should also get a slighly better deal
  35. 1animal1
    9,978
    i agree but only because i think the Saikou will be easier to fit due to the supplied bracket....... the other does look well, worth noting though that you will scratch the can whilst installing as the A3 was tight, the S3 is simply daft depending on where you put it....i found myself using a tin of satin black on the can once installed to neaten it up
  36. s3tle
    s3tle Member
    239
    so i'm guessing those prices have put people off!! just wanted to illustrate the worst case!!
    I'm not really fussed as to which one, or indeed if i just get one for myself so if anyone is interested in either pm me
    Thanks!
  37. 1animal1
    9,978
    i dont think anyone has bowed out fella.... just start a list like this ;)
    copy and paste people
    S3tle
    1Animal1
  38. thorsy22
    thorsy22 Member
    308
    S3tle
    1Animal1
    Thorsy22
    I'm still in too, seeing as payday is but a few days away :icon_thumright:
    (Would prefer the DD42 but if its going to be almost £100 then its going to be that bit too expensive when compared to the Saikou Michi in my opinion.)
  39. Dani_B19
    9,343
    394
    Im in but dont want to spend daft money thats all, i just want a catch can thats neat and will actauly offer a baffle/filter to stop oil and water vapour back into the inlet whcih my toyosport one is doing.
  40. 1animal1
    9,978
    dont forget you will be able to sell the toyo jobby and offset the cost mate :)
