Oil Catch Can mini group buy anyone? including PCV system simplification.
OllieH Mar 3, 2010
  1. Westy
    Westy Well-Known Member
    17,443
    1,105
    All the oil breather system is ok because there's no real pressure in it that requires tight clamping. The 2 hoses that come off the inlet mani are under pressure and need to be secure. When I first did the catch can install I lost the bolt i'd clamped into the 1/2 inch pipe under the mani and now the other bung has gone! Got to try and find something to bung it to get me home tonight!
  2. thorsy22
    thorsy22 Member
    308
    Now I want to cap the vacuum source under the manifold. It's not going to be used, all the pressure is positive coming from the crankcase and upper breather anyway and it'll be caught in the can. The fumes will also pull via the TIP connection when under acceleration. I used a small length of 3/8" ID pipe with a bolt screwed tightly into it
    Borrowed the above from the uk-mv's site linked at the beginning of the thread, so thought the port on the intake mani was 3/8 or is this fella using smaller dia. hose to make a snug fit?
    As for the brake servo plug (and mani plug), was thinking of coating the plug in superglue stuffing it in the hose and jubilee clipping it all up, should make a good seal I think (unless its going to degrade the hose).
  3. Westy
    17,443
    1,105
    I dont even know how my bung has come loose. It was a really tight fit and it was jubaleed in real tight. I'll have a good look on my lunch break to see whats hapened. I'll have to take a trip down to a hardware store and try to find something to get me home.
  4. thorsy22
    thorsy22 Member
    308
    Good luck finding a plug, your not going to want to drive that home in its current state!
  5. Westy
    17,443
    1,105
    I know exactly where I heard the clunk so I might got searching the work carpark for my old plug, I'll check the situation at lunch in an hour.
  6. 1animal1
    9,978
    to be fair mate i dont think it will give you much of an issue, mine and plenty do run with breakages around there...... obviously it isnt ideal but it should be fine id have thought
  7. Westy
    17,443
    1,105
    Come again?
  8. 1animal1
    9,978
    sorry mate was rushing that haha.....you should be fine, it wont run brilliantly cos obviously its a boost leak...but it should get you home with no probs...that said if you really wana plug it just elastic band a super thick condom onto it :)
  9. Westy
    17,443
    1,105
    Yeah the boost leak isn't the real issue mate it's the unservo'd brakes which worry me! I'll bung it with something to get me home then find something more appropriate.
  10. S3 TAM
    S3 TAM Pocket now empty
    624
    10
    westle have you got the old stuff you ripped off still, you can take the one way valve from that and redo that section with new silicone...
  11. Westy
    17,443
    1,105
    It's this bit mate. We got an old sump plug from the SAM Centre if you remember correctly but he only had one left!
  12. S3 TAM
    624
    10
    Yeah i know, on the other stuff we took off there is a one way valve like above but with only two connecting ends one in and one out. so you dont have to block anything off. i read it on here ASN somewhere I also spoke to dean about it. i'll try and find the thread.
  13. Westy
    17,443
    1,105
    Are you sure mate? This pic shows the ***** that comes off of a BAM engine and the only 1 way valve has 3 chanels. I think the older engines on an A3 have a 2 chanel 1 way valve:
  14. S3 TAM
    624
    10
    Sorry mate my mistake you need to get one of these from audi it not on the bit you've taken off.
    I'll try and get part number off etka now.
  15. Westy
    17,443
    1,105
    Ah yes I know about that one. I'm sure Audi wont sell it seperately without the joining hoses. Hopefully that valve will be upto the same job, are they different sizes?
  16. S3 TAM
    624
    10
    Etka say:
    non-return Valve
    QTY 2
    P/N058 905 291
    9.28 euros
    I give you 5 fiver and i'll have one off you if you want. if there only a tenner
  17. 1animal1
    9,978
    was gonna say, westle i thought you meant the pipe coming off the bottom of tyhe mani which shouldnt affect the servos as you will styill have the one way valves in line
  18. Westy
    17,443
    1,105
    Just fixed it at lunch :)
    The bung was still there nice and tight, instead the pipe that the one way goes into had popped off because I didn't bother jubaleeing it! Good job it held out for the ring trip!
    So..... new word of warning. Make sure you clip everything up nice and tight :)
  19. thorsy22
    thorsy22 Member
    308
    Westle, you should have a warning of the day mate! lol
    Seriously though, glad it was only a quick fix!
    If that 2-way valve works, group buy?
  20. s3tle
    s3tle Member
    239
    It's a shame as dealers must throw away so many of these valve when replacing brake booster pipes, which fail on most vag cars, could go and ask one of the tech's if they could hang on to an old one for you, guess it depends how friendly/helpful your dealer is!!!!
    i got mine from a Skoda octavia brake booster assembly.
    If you can't order new one direct from dealer or get old one ECS list them for $13
    Home Page > Search > 058 905 291 > ES#259630 In-Line Check Valve - 058905291K
    not sure what pressures are involved but fuel check valves?
    8mm Fuel Non Return Aluminium Check Valve on eBay (end time 07-Oct-10 16:47:18 BST)
  21. thorsy22
    thorsy22 Member
    308
    "Slightly off topic"
    S3 Baby, how come you've got a t-piece in the 3mm silicone hose just behind the N249 valve in your pic after doing the N249 bypass? Thought it was just one piece of hose from the underside of the intake manifold to the top of the dv?
  22. thorsy22
    thorsy22 Member
    308
  23. Westy
    17,443
    1,105
    @ Thorsy22, S3 Baby has a boost gauge and that's where he's plumbed it in.
  24. thorsy22
    thorsy22 Member
    308
    Ah, cheers Westle.
  25. b1gdave83
    b1gdave83 Member
    159
    Have you ordered them yet? I'm up for one of those catch cans!
    I sure open venting can cause other problems, because it's suppose to be close loop system, so all air is measured and accounted for.
    (might be talking bull, but I'm pretty sure I read that somewhere)
  26. s3tle
    s3tle Member
    239
    Hi Dave no not ordered yet, should be looking at around £70 delivered, hopefully will order in about a weeks time, if you want one add your name to this list;
    S3tle
    1Animal1
    Thorsy22
  27. b1gdave83
    b1gdave83 Member
    159
    Thanks, I love these group buys :yes:
    S3tle
    1Animal1
    Thorsy22
    B1gdave83
  28. b1gdave83
    b1gdave83 Member
    159
    Are we ready to buy these yet? nearly been a week
  29. 1animal1
    9,978
    Dave we are waiting on Dani mate, to be fair none of us are in a big rush either so also hoping to get more people involved...... just go with the flow mate :)
  30. b1gdave83
    b1gdave83 Member
    159
    Lol Ok.... I'll just chill :cold:
  31. Dani_B19
    9,382
    403
    Or yeah, go on blame me :), haha. So is their 5 of us then? I thought paul wanted in on this too?
  32. 1animal1
    9,978
    haha your an easy target ;)
    dunno bout Paul.....
    if everyone lets us know when they are ready to go, then S3tle can order....as said though im in no rush, you could say im easy, whenever ;)
  33. thorsy22
    thorsy22 Member
    308
    At the moment I'm going to have to miss this, been told I need to replace my cat and offside lower wishbone so money has to go on them now :-(
  34. Dani_B19
    9,382
    403
    Tim your easier than a hooker at wayne rooneys private bashes, lmao :).
  35. Dani_B19
    9,382
    403
    Tbh thorsy i know what you mean, im still way off buying all the bits i need for my rebuild, haha.
  36. The Doctor
    The Doctor Well-Known Member
    1,394
    189
    Hi guys, re mounting the can on the firewall, where is the pollen filter flap that OllieH refers to (see his method below from page 6 of this thread)? Also, once drilled, I assume that the process is then to insert a bolt through the hole in the firewall to attach the bracket on the can to, right?
    "And decided to have another go at getting my hand into the pollen filter flap so I could mount straight onto the firewall. Had to remove the TIP so I could drill a hole through the bulkhead. I positioned the hole about 10mm to the right and 10mm down from the right hand stud (which I had previously cut off) There are cable runs behind the firewall which come very close to where you will be drilling. All I did was hold the cables up while I drilled through. Be very carefull when doing this. Don't forget you can still mount using the bracket and left hand stud as shown on page 5 of this thread. You'll wanna use a round file to get rid of the burrs aswell afterwards."
  37. 1animal1
    9,978
    pics :)
  38. Andy123
    Andy123 Member
    260
    Have these been ordered yet as I would like to get one also? Thanks andy
  39. S3 TAM
    624
    10
    Right i have just received my BSH Oil catch can off ebay. after 1 and half months of waiting.
    there are no baffles inside and it is open at the top which i knew when buying my question is what can i use as a baffle to put inside and any ideas on how i can close the top.
    I was thinking to knock the top out and put wire wool inside then fill the top with metal filler will this work?
    I now know i should have not been impatient and waited for the group buy. Doh
  40. 1animal1
    9,978
    blimey guvner......thats a task :)
