OIL CATCH CAN FITTED TO BKD ENGINE
tdi-man Aug 3, 2013
  1. tdi-man
    tdi-man Well-Known Member
    1,783
    64
    just fiited oil catch can to my engine...
  2. bosun
    bosun New Member
    26
    I nearly did this to my Golf then decided against it (More like couldn't get the hoses to fit).
    Looks good though.
  3. tdi-man
    1,783
    64
    I used 19mm internal diameter pipe into a 22mm joiner and then I 19mm to 13mm reducer pipe to
    my 15mm catch can.
    19mm pipe just pushes on the crank case outlet and other 19mm pipe pushes into genuine. Pipe
  4. jaye2992
    jaye2992 Member
    98
    21
    liking this mod! what turbo you running if you don't mind me asking?
  5. tdi-man
    1,783
    64
    Turbo techies hybrid.
    Will put more pics up tomorrow of pipe connection
  6. tdi-man
    1,783
    64
    using 19mm internal pipe at the moment but may get some 16mm internal dia so can remove joins.
  7. Mikemc
    Mikemc Scooby Slayer VCDS Map User
    1,024
    37
    Where did you get then can from mate?
  8. tdi-man
    1,783
    64
  9. TDI140
    TDI140 Well-Known Member
    1,632
    175
    Nearly as nice as mine lol ;-) ahha
    nah good work mate
  10. tdi-man
    1,783
    64
    thanks not happy with it at the mo so work in progress...
    does the job.....
    thanks
  11. TDI140
    1,632
    175
    I want to make some sort of bracket for mine i dont like using crappy cable ties although they hold it well
  12. Tomwebb
    Tomwebb A3 2.0 tdi s line 170
    60
    Can someone explain the advantages of having this, I'm hopefully going hybrid soon and this seems like a cheap mod?
  13. TDI140
    1,632
    175
    It cost me about £160 ish as i had full silicone hoses made in red
    its stops oil going i to the intake which ends up in the turbo inlet which is bad
    also stops the oil from there then reaching intercooler hoses and trust me it works ive had mine for about 8 months ive empties a full load and its about 1/5th the way full
  14. tdi-man
    1,783
    64
    didnt want to go down the line of getting hoses made so bought the below.
    oil catch can - £23.00
    tie wraps - £2.00
    silconhose joiners -£10.00
    silcon hose reducers - 10.00
    silcon hoses - £10.00
  15. Tomwebb
    60
    Why doesn't it come as standard?
  16. danb986
    danb986 In awe of VCDS Team Daytona
    523
    Because the standard system is designed to be maintenance free, whereas this method will require you to monitor it and empty it when full. The average motorist isn't going to want to do this, or even know how to.
    I'm sort of tempted, but the new common rail engine hasn't used a single drop of oil. Unlike my old BKD A3 which needed topping up regularly.
  17. bigal23
    bigal23 Member
    208
    has anyone installed the provent 200?
  18. TDI140
    1,632
    175
    Because most people here dont really have a clue what it does so if they dont know i doubt they will empty it so not worth the hassle by audi also
