Oil catch can 1.8TQS ??
Bradderz_1988 Jul 18, 2011
  1. Bradderz_1988
    3,946
    235
    Basically thinking of getting one and want some insight.
    Any one got one fitted (pics would be great) ?
    Any one got a write up/pics on fitting one?
    Thanks in advance.
  2. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group S-line owners group
    3,705
    643
  3. aragorn
    18,129
    763
    Basically, gasses blow by the piston rings as part of the engines normal operation, and the breather system routes these back into the inlet manifold to be burnt off. As the gas travels thru the crankcase it can pickup oil vapour and carry this into the inlet as well. The oil reduces the intake charges octane level slightly, so can reduce power, as well as clarting up the inlet etc.
    The engine has a seperator built in, whose job is to try and "catch" that oil vapour and let it return to the sump. Its not that great though, so people add an external one in the form of a catch can. This can then be vented back to the inlet, or vented to atmosphere depending on your preferences.
    I find Atmo venting can make the car stink of oil vapour when stopped at lights or in traffic.
  4. Westy
    Westy Well-Known Member
    17,443
    1,103
  5. B5NUT
    3,705
    643
    Would he same work for a TDi engine?
  6. Bradderz_1988
    3,946
    235
    Hmm interesting good write up all though it's not on a b5 so pipe work will be different so I'm still none the wiser lol may have to go through this a few times to get a good understanding of it !
    You say the pancake valve was venting both ways ???, I had mine off the other day and you can blow through it both ways with no resistance is this right or wrong ??
  7. Westy
    17,443
    1,103
    Yeah it shouldn't do that mate.
    I know the layout of the pipes will be different but the principle is the same. Since I fitted my catch can and started venting to atmosphere my TIP, boost hoses, and throttle body have been clean as a whistle.
  8. Jason.s
    Jason.s Active Member
    2,879
    348
    Theres a fairly recent thread on Audizine about simplifying the PCV system and various vac hoses too. Which is obviously in the B5 section so would make a bit more sense then trying to copy from a transverse set up.
  9. Bradderz_1988
    3,946
    235
    Any chance of a link mate ??
  10. bmarshall
    bmarshall Member
  11. Jason.s
    2,879
    348
    DIY for PCV system removal? on a quick search. Link to the B6 guide within that link too at the top.
  12. Bradderz_1988
    3,946
    235
    Bit of a thread revival since noticing the IE VTA catch can im thinking of doing one for my car somewhat like this :-
    Im thinking of maybe even doing it back to the exhaust with a scavenger plug thingy, whats your thoughts ??
    Also where in the UK does the crankcase adapter with a 10AN fitting ??
  13. Bradderz_1988
    3,946
    235
    Will this need a check valve in piping between catch can ??
