oil and water feed
jezzy Sep 12, 2012
  1. jezzy
    jezzy Member
    768
    Hi
    Can anyone tell me how many washers the oil and coolant banjo bolts to the turbo have?
    Many thanks
    o and by the way if your putting an xs manifold on
    Take the ****ing head off, otherwise the neighbours, misses and you friends will see the monster inside you.
    Rant over and thanks for any replies
  2. Westy
    Westy Well-Known Member
    17,443
    1,103
    I'm pretty sure I put 1 either side. Make sure you tighten them up as my water one leaked when the engine was running!
  3. jezzy
    jezzy Member
    768
    Thanks westy
    much appreciated glad i bought 4 then
  4. Westy
    17,443
    1,103
    I bought a whole assorted box from halfords as I wasn't sure what I'd need either.
    Mani all on ok now then? Mine was done with the head off but I can imagine how difficult it must be with it on!
  5. <tuffty/>
    21,144
    3,832
    On a K04 there are 7 coolant washers (4x for water pipe from block, 3x for the pipe from front of engine (has a spacer), 2 oil washers and the oil drain pipe gaskets
  6. <tuffty/>
    21,144
    3,832
    ...and tbh... OEM ones work the best... I have seen the copper washers from other sources turn to dust...
  7. Westy
    17,443
    1,103
    Jezzy's only on about the 2 banjos that bolt to the turbo I think.
  8. Westy
    17,443
    1,103
    Oh that's something to keep an eye on then, thanks.
  9. jezzy
    jezzy Member
    768
    Nope, its in the boot
    ive been trying to cut down number 2 and 7 studs.
    Angle grindered the first one and couldnt get the nut on it, then the second ive been trying to cut down the just a hacksaw blade.
    my fore arms kill.
    Hopefully tomorrow all back together and running.
    heres a useful trick my neighbour showed me.
    if like me you angle grind your stud doh and cant get the nut on the stud. take an m8 nut (manifold studs this is) saw three channels inside the nut (hacksaw blade works well) then put the nut on the stud and tighten, this will re thread your stud, the channels in the nut catch the swarf and allow the nut to turn (this was a god send and bloody cheap way of re threading the stud) a tap and die set is to big to fit, i did try.
  10. jezzy
    jezzy Member
    768
    yes just the two banjos on the turbo and i bought them for coulson audi, bloody lovely r8 gt in the showroom.
    Thanks tuffy
  11. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    What version manni is it?
  12. jezzy
    jezzy Member
    768
    v2 dave
