Oil advice and recommendations here
oilman Jan 29, 2009
  1. oilman
    oilman Active Member
    347
    26
    As per title really.
    If you have any oil related questions etc please post them here and we will do our best to help.
    If you would like an oil recommendation please add the following info.
    Make -
    Model -
    Year -
    Mods -
    Use (road/track)
    Hopefully we can be of some use here.
    Guy
  2. oilman
    347
    26
    Anyone for some oil advice? Feel free to ask.
  3. liam
    liam waiting, waiting, waiting
    171
    Make - Audi
    Model - 8P S3
    Year - 2009
    Mods - Stock (+ Stage 1 ECU tune, GIAC/APR etc)
    Use - Mostly road, couple of track days per year
    And how often would you recommend changing the oil (ie. every 7500km/5000m or so)?
    :icon_thumright:
  4. oilman
    347
    26
    Are you on the fixed or variable service schedule?
    Guy
  5. liam
    171
    15,000km set intervals.
    Same as our GTI. I change the oil on the GTI myself at half intervals. So am guessing the same will apply to the S3 too.
  6. oilman
    347
    26
    Something that meets the VW504.00 spec, especially if the car is under warranty.
    What can you get out there?
    Guy
  7. liam
    171
    Would probably stick to something from Mobil or Castrol I guess.
    We use Mobil 1 0W-40 in the GTI and the MINI.
  8. oilman
    347
    26
  9. AndymacA4
    AndymacA4 Member
    165
    Hi, whats best for my 2001 B6 Audi A4 1.8T. It has 77K on the clock, runs 10,000 mile fixed interval.
    It has no internal modification, but it does have aftermarket chip work that has eased the 150bhp up to about 180bhp-190bhp approximately.
    The cost of the oil is not an issue. What is the very best stuff for my car engine to ensure long life and happy motoring?
    Andy
  10. oilman
    347
    26
  11. scottyboy99
    scottyboy99 New Member
    Hi, I know this isnt exactly oil related, but im hoping you can put my mind at rest. I have just bought an 06 A4 1.8t petrol, and im now working away with my wife driving it. My worry is her putting diesel in the petrol engine( as our last car was diesel). Is this possible do you know? I know you can put petrol in the diesel engine by mistake, and you can buy a device to prevent you from doing so, but cant seem to find any info about accidentally putting diesel in the petrol tank. Any info greatly appreciated.
  12. oilman
    347
    26
    In theory the nozzels are different siezes so that it should not happen, but it does. If it does happen it all depends how much has gone in there. If she fills the tank then you have a problem, it will need to be drained and flushed.
    Guy
  13. scottyboy99
    Ok cheers for that guy.
    scott.
  14. SWAMP DONKEY
    SWAMP DONKEY New Member
    Hi Oilman
    Can you give me a oil recomendation please.
    Make - Audi
    Model - S3
    Year - 2003
    Mods - None
    Use (road/track) - Fast Road
    cheers, much appreciated
  15. oilman
    347
    26
  16. oilman
    347
    26
    Anyone for advice?
    Feel free to ask.
    Guy
  17. audi58
    audi58 Member
    134
    Make - AUDI
    Model - A3 2.0 TDI 140
    Year - 2007
    Mods - Engine Remap
    Use (road/track) Road
    Really not sure what engine oil to use? There are loads out there.
    Any recommendations?
  18. oilman
    347
    26
    Anything that meets the VW507.00 spec, these will be 5w-30. All these are approved http://www.opieoils.co.uk/c-754-vw-50700-oil.aspx
    Guy
  19. Jonay
    Jonay Member
    274
    Make - Audi A3
    Model - 2.0L TDI Quattro Sport
    Year - 2005 (55plate)
    Mods - Nil
    Use (road/track) - A-Class roads and B-Class Roads, about 15k mi p/a
    I've only just bought this, and i had a look at the oil, and it is BLACK. Despite the service manual being kept up to date, I doubt this has had an oil change in the last 10,000mi.
  20. joedredd
    joedredd 2006 A6 S line 3.0tdi Quattro Avant VCDS Map User
    200
    27
    I suspect its on a longlife service, every 20K. Just do it every 7.5 - 10k much nicer to the engine.
  21. lincoln_dj
    lincoln_dj Active Member VCDS Map User
    471
    61
    here's one for ya oilman....
    Model - Audi A3 3.2 V6
    Year - 2004 (78k miles on clock)
    Mods - Standard
    Use (road/track) - normal road use, 6/7k per year
    dont plan on doing "longlife" servicing, just oil & filter change every 12 months, regardless of miles.
  22. Jonay
    Jonay Member
    274
    What kind of oil (grade etc) do you reccommend? I'm new to diesel!! :)
    J
  23. oilman
    347
    26
    Yes, that sounds like the longlife service schedule. We're hearing a lot of things about sludge build ups etc from the longlife schedule, JoeDredd is right just change it a bit more often.
    [FONT=Trebuchet MS, sans-serif]If you want to clean it out, the best thing you can do is drain out the oil that is in there, put in some cheap (the cheapest you can find) mineral oil and run the car for 15 minutes so the oil gets nice and warm. After running it, drain out the mineral oil and put in the correct oil.[/FONT]
    After that I'd run the car on a 505.01 or 507.00 (but change it before the car tells you to)
    [FONT=Trebuchet MS, sans-serif]505.01 - http://www.opieoils.co.uk/c-751-vw-50501-oil.aspx[/FONT]
    [FONT=Trebuchet MS, sans-serif]507.00 - http://www.opieoils.co.uk/c-754-vw-50700-oil.aspx[/FONT]
    [FONT=Trebuchet MS, sans-serif]They are all good oils, so make your decision based on any brand/price preference you have. [/FONT]
    Tim
  24. oilman
    347
    26
    It's not always the grade, it should meet the VW diesel specs. 505.01 is for the PD engines, 507.00 is for longlife servicing, or PD engines fitted with diesel particulate filters. Pre-PD engines aren't too fussy and are usually happy on a 5w-40 or 10w-40
  25. Jonay
    Jonay Member
    274
    Thanks a lot!
    Btw your links require a login.. :\
    What does PD stand for? (sorry to be a nuisance!)
    And for draining the oil, is it just simply the case of opening up the sump plug and letting it run out?
  26. joedredd
    200
    27
    I use Castrol edge 5-30, but advice from opie is spot on.
  27. oilman
    347
    26
    Edge 5w-30 is a very good choice, but I would still change it sooner than the offical service schedule.
    Jonay, I'm not sure why it's asking you to log into those links, they should be fine and only ask you to login to buy. Anyone else have that problem?
    PD stands for Pumpe Deuse, basically a high pressure oil pumping system
  28. joedredd
    200
    27
    I change it every 5-7.5k is that often enough?
    Yes I get the same log in requests
  29. oilman
    347
    26
    Yes, that's often enough. Leave it 8-10k if you want.
    Not sure why you are getting log in requests. I'm logged out of all the Opie stuff and it's letting me in.
  30. Jonay
    Jonay Member
    274
    doesnt really matter, I found the stuff on your site using the link in your sig :)
  31. oilman
    347
    26
    Any advice needed ?
    Ask us here, will be happy to help :)
    Oilman
  32. nitrotg
    nitrotg New Member
    24
    Make - Audi
    Model - a3 2.0 tfsi dsg
    Year - 2006
    Mods - stage 1 chip, BSH Intake, Milltake Exhaust back, 3" high-flow race catalytic converter, Upgraded fuel pump
    Use - Road, Fast..
    what do you think?
    get the login/pass too :/
  33. oilman
    347
    26
    Hi
    I would use a 5w-40 synthetic and you will find those through the link below.
    5w-40 engine oil | 5w40 oil
    Out of those, the best ones are the Fuchs/Silkolene Pro S, Millers CFS/CFS NT, Motul 300V, Redline and Gulf Competition. The Motul 8100 X-Cess, Millers XFS, Fuchs Supersyn, Shell Helix and Mobil Super 3000 are good, cheaper alternatives.
    Tim
  34. DannoS3
    DannoS3 The NEED for SPEED :)
    60
    Make - Audi
    Model - S3 8P
    Year - 2007
    Mods - Full Decat (near future - Induction and Mapping Mods)
    Use (road/track) - Road
    I need to give the girl a full service in the next month. What oil would you recommend using? I have about 30lts or so of VW's Platinum
    Dan :)
  35. oilman
    347
    26
    Hi
    The oil you need depends on the service schedule the car is on. If it is on an annual/10k miles service, you need an oil that meets the 502.00 specification. If it's the variable service schedule, you need an oil that meets the 504.00 spec.
    502.00 - VW - Engine Oil - 502.00 (502 00)
    504.00 - VW - Engine Oil - 504.00
    The 504.00 oils are all good oils, so make your decision based on any brand/price preference you have. With the 502.00 oils, go for a 0w-30, 5w30 or 0w-40 or 5w-40.
    Tim
  36. marrick92
    marrick92 Member
    68
    Make - Audi
    Model - A3 1.8t
    Year - 1998
    Mods - Front mount intercooler, 007p, induction kit, soon to get a k03s turbo, TIP + remap
    Used on the road
  37. oilman
    347
    26
    Hi, Marrick
    For your A3 1.8 we would recommend a good quality 5w-40 you can find plenty to choose from here 5w-40 engine oil | 5w40 oil
    We would recommend a Fuchs ProS, millers CFS, Redline, Gulf competition, or the Motul 300V.
  38. DeviousG
    DeviousG New Member
    2004 A3 2.0 FSI (non turbo) - ive already drained current oil, going to buy cheap oil let it run and warm up for a bit then drain it out and top up with a quality oil - what do you reccomend ?
  39. oilman
    347
    26
    502.00- VW - Engine Oil - 502.00 (502 00)
    504.00- VW - Engine Oil - 504.00
    The 504.00 oils areall good oils, so make your decision based on any brand/price
    0w-40 or 5w-40.
    Tim
  40. Paradox1
    Paradox1 Well-Known Member
    1,833
    88
    oilman Need your advice bud
    Model - mk4 golf gti 1.8T
    Year - 2002 (100k miles on clock)
    Mods - stage 2 remap,fmic, full exhaust etc.(fast road/track use.
    I do regular servicing and oil changes. Have been using Mobil 1 super but was was planing on changing to quantum vw oil but I'm unsure if I should use 10w 40, 5w 40 etc?
