Oh so quiet....
AR-rkon Jan 8, 2012
  1. AR-rkon
    AR-rkon Mod back in a "B" Staff Member Moderator Regional Rep Team V6 Team Silver Audi A6 Audi A4 Audi Avant Owner Group
    1,913
    166
    Well after a prod from foxy, heres what I've been upto with the a4 recently.
    I've dynamatted the back end to help with the bass and various rattles, after finding a roll in halfords for a fiver :)
    Fitted a new stereo (kenwood) to replace the alpine unit (now for sale if anyone wants it) so I can have some more musical options (USB, iPod, aux, cd) instead of just iPod and cd.
    Replaced the front discs and pads, cv joints, and repaired the front bumper skirt (as it was catching on kerbs and the like).
    Next job is to book in an not to see what other issues are lurking before mine expires in may. Then tackle the rear discs pads and bearings :( not looking forward to that one... Will get abs rings and bolts ordered as no doubt they'll shear off...
    Pics to follow :)
  2. Sandra
    Sandra Administrator Staff Member Administrator TeamMisano TFSI Owners Group Audi S3 quattro s tronic Platinum Supporter Audi Main Dealer
    27,815
    10,917
    Certainly sounds like you have been busy.
  3. AR-rkon
    1,913
    166
    Haha just a little, I'm sure it's a form of addiction, started with the intention of JUST doing the CVs lol... Now look what's happend and spend about £150 instead of £25
  4. Foxmeister
    Foxmeister Fired Up!
    1,785
    :respekt::arco:
  5. AR-rkon
    1,913
    166
    ok, ******... no pics :banghead: damn iphone has had to be restored :sob:
  6. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 saloon Team Akoya TDi
    15,165
    1,124
    Should have gone android :ninja:
    The rears are easy.
    Just make sure you got a press handy.
    the caliper bolts on mine was a *****.
    I replaced 2 or so i think.
  7. spartacus 68
    spartacus 68 Active Member quattro Audi A2 Audi Avant Owner Group
    391
    61
    Worth opening the bleed valve when you screw the piston bore back in. Can be a hassle at the best of time. I also use a little Lockheed red grease (for hydraulic applications) under the piston dust sleeves and on the slide bolts. Double-check the handbrake cable ends... which suffer corrosion, etc. If in any doubt - then replace. Unfortunately part is £50. I also dismantled handbrake spring on caliper as it was seized, grease up, etc. I fitted Bosch pads and Zimmerman discs.
  8. jcb
    jcb Active Member
    4,132
    13
    i have just done my rear brakes, both CV's and both bearings.
    Had to remove the calipers to get them wound in after fully removing the piston!
    in actual fact it was faster doing the second one this way that messing around with the poxy rewind tool.
    CV's were a doddle once I had pulled the shafts.
    did the bearings without a press using the patented (or not) pikey press free method!
    http://www.audi-sport.net/vb/a4-s4-...b-pikeys-those-without-hydraulic-presses.html
