OH NO...
Adam-D Aug 6, 2008
  1. Adam-D
    Adam-D Member
    457
    need a lil help...
    my 1997 avant sohc v6.
    i head a creak a week ago, was unsure what it was.
    so just now when reversing it creaked and i can make it do it.
    more so as i got out and pressed down on the passenger side wing and it creaks.
    what could it be, the suspension seems more complex than i am used to fixing.
    any ideas?
  2. Z82
    Z82 Member
    454
    Could be anything but I had that and it was a broken spring
  3. Adam-D
    Adam-D Member
    457
    if i press down on the wing or pull up it does it.
    im getting a shock and spring kit for it, but could it be anything else? it has done 76k if im fitting a kit if there is anything else i can change while im there,,,..
  4. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    creak? no clunk? could be something as simple as a spring seat or a creaky bush.
    any other symptoms
  5. Adam-D
    Adam-D Member
    457
    no it just creaks. no knocks
  6. Broken Byzan
    13,237
    465
    That will probably be one of the arm bushes, locating which one is not easy tho as there are loads in there
  7. aragorn
    18,150
    766
    if ones creaking then they're likely all well past their best.
    If you can afford it, replace them all.
  8. Adam-D
    Adam-D Member
    457
    wasn't there a kit of them you can buy? with the arms and the bushes etc?
  9. aragorn
    18,150
    766
    i bought a kit on ebay for £115 quid with all 8 arms and new droplinks track rod ends and bolts
    Its been fine so far but ive only had it on the car a few months. I dont expect it will last the same length of time that the original audi parts did, but i'd expect it to last a reasonable amount of time
  10. Adam-D
    Adam-D Member
    457
    i do about 5k a year so, it should last a few years i guess
