  1. what offset 18" or 17" wheels does the a4 use?
  2. PaulJC84
    PaulJC84 Owner
    2,922
    17
    Mine are ET35 but they are 19" think 17" are ET 45 and 18" need to be ET35
  3. cheers, i was getting a bit confused as different places say different things.
    now the decision, do i get 17's or 18's ?????
    im swaying towards 17" rs4's at the mo. i want whatever i get to look like it came on the car, dont want it to stand out to much (although its decked), just update the looks
  4. PaulJC84
    PaulJC84 Owner
    2,922
    17
    Na mate get 18s you will regret it if you dont.
    Look at the new S-line A4's, the 18s dont look that big on them.
  5. Broken Byzan
    13,244
    468
    Go for 18's m8, theye will be the same rolling radius as the 16's you have, At least thats what i want, nay NEED to do,lol
  6. Olly__K
    Olly__K Guest
    as far as im aware, and please correct me if i'm wrong, but doesnt the offset stay the same no matter what size of wheel ?
    the offset is how the far wheel sticks out/sits in from the arch.
    The tyre profile is the thing that changes, so 45 for 17's, 40 for 18's 35 for 19's, to keep the rolling circumference the same
  7. Broken Byzan
    13,244
    468
    Thats right, its just generally the width increases too, this can cause the tyre/wheel to foul the suspension or arch, therefore sometimes it is necessary to change to ofset to space the wheel accordingly.
  8. This is all true but the profile should only change in relation to the tyre width in order to keep the same rolling radius since it is a percentage of the width itself.
    For instance, my car had 225 x 45 x 17's on it as standard which gives a rolling radius of 63.43cm
    45% of 225mm = 10.25cm
    x2 [because there are two sidewalls] = 20.25cm
    + 17" [43.18 (17x2.54)]
    Total = 63.43cm
    For the 225 x 40 x 18's that I now have on there...
    40% of 225 = 9
    x2 = 18
    +18" [45.72 (18x2.54)]
    Total = 63.72cm
    So as you can see the radius difference is within 3mm and tolerance is easily within that of the difference between a new and worn tyre.
    /ubbthreads/images/graemlins/smile.gif
    T
  9. jonnya
    jonnya Member
    102
    Offset is actually the distance between the back of the mounting hub and the centre line
    of the wheel. Wide wheels can require a change in offset to avoid fouling.
  10. AndyMac
    AndyMac Moderator Moderator
    9,832
    46
    Definately go with 18's. I made the mistake of getting 17's at first and they look too small, had to wait a couple of years before I could justify getting 18's
