Offset & Tyre Size
Daniel97 Dec 18, 2011
  1. Daniel97
    Daniel97 Member
    137
    I do not understand this period.
    So my 2003 A4 Avant. What offset are my 16".
    If i buy new wheels - what size offset is the minimum and maximum i can buy .. and what tyre size to i buy in relation to the offset. 18" Wheels btw.
    Thanks!
  2. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,250
    192
    18" You want 235/40/18
    I run ET33 which is quite far out. I would think that'd be your limit and i wouldn't advise much higher figures than standard.
  3. Daniel97
    Daniel97 Member
    137
    When you say higher you actually mean lower don't you?
    Lower number is further they stick out?
  4. AudiLeon
    2,250
    192
    When I say higher figure i mean if the standard figure is 43 i wouldn't go to 48 as they'll sit too far in.
  5. Daniel97
    Daniel97 Member
    137
    Okay so i want between 33-40 really .. not a fan of spacers :)
    18 or 19 on the Avant?
  6. quattrojames
    14,068
    585
    You'll not go wrong on ET35 with an 8" wheels, you can go a couple of mm either way with no real issues.
    18's or 19's are personal choice, the forum contains fans of both.
  7. Daniel97
    Daniel97 Member
    137
    Any pros & cons for each?
  8. quattrojames
    14,068
    585
    Just the obvious.... tyre cost vs ride quality vs looks etc
  9. Daniel97
    Daniel97 Member
    137
    so the bigger i go the harsher the ride, more expensive the tyre and looks better (arguable)
    So 18's are my best choice then
  10. CMD
    CMD Pointing Forward's!!!!!!!!!
    3,015
    17
    Not true. 19's or 18's give the same feel. I have run both and feel no difference.
  11. paul20v
    paul20v Audi fanatic
    1,114
    On a smooth road maybe
    It standards to reason the more profile of tyre you have the better the ride quality
    Unless you live in a part of the uk that has smooth roads
    That is a very rare place indeed .
  12. CMD
    3,015
    17
    I live in S. Wales Paul and there are NO smooth roads out here apart from a 500 mtr section of M4 just past Bridgend. The sport suspension on my A4 was firm and now i'm on a combo of coilovers it's still just like the sport setup the 19's or 18's just feel the same to me.. The polo we have Now that's harsh even on a 45 profile.. I feel it's the suspension setup not the wheel and tyre setup
  13. holmefield
    holmefield Active Member
    518
    42
    GO BIG OR GO HOME.....Nar its personnal choice i run 19" X5 alloys 9J front 10J rears with 225/35 fronts and 235/35 rear my front E.T IS 28 just inside the arch and i DO mean JUST and rear ET 27 out of the arch by 6/8 mm but thats because there 10J with 18mm adapters.....
    As for the ride i ran 19" porsche cayannes on my A3 with 215/35s all around and had Eibachs on and the ride was to hard, but with my current setup on the A4 and standard sport springs the rides fine, just avoid potholes....
  14. BahnStormer77
    BahnStormer77 BahnStormer
    2,778
    60
    For an 8J (8") wheel, the S4 Avus III's are ET45.... I'd advise for going for that as the safety option or within 5mm of that. Between ET45 and ET40 if you can't get exactlyt he same as the S4 spec.
    For looks, I wouldn't go below ET50 - they'll sit in too far.
    Some people will swear by ET33 or ET30, sometimes that looks usable, but it does look more than a litte risky on others as they will stick out a LOT, I wouldn't advise buying anything lower than ET40 unless you have the option to try before you buy.
