off topic but professional advice needed
Izzy1 Nov 19, 2008
  1. Izzy1
    Izzy1 Vorsprung Durch Technik
    391
    10
    i know this probably isn't the best place to put this but i'm going to do it anyway. need your help on this one!
    started up my bora (TDI) last night and as i pulled off it just didn't seem right. so i drove a bit more and the whole car started to flutter and i wasn't getting much power. engine seemed to be shaking the whole car.
    after putting it on vagcom i got the following fault codes...
    18074 - Valve for pump-jet: cylinder 1 (n240): electrical malfunction P1666-35-10 - - - intermittent
    16685 - Cylinder 1 misfire detected P0301-35-00
    i take it it's misfiring and that's why it doesn't drive properly.
    is this an easy fix or will this cost me some monies?
    all comments and advise welcome
  2. aragorn
    17,872
    686
    not familiar with the diesels but firstly i'd be checking the wiring to that injector...
  3. Izzy1
    391
    10
    i've also posted on ukmk4 forum as i'm after a quick answer for this. need the car back on the road asap.
    i've been told i need to check the wiring looms and if possible to just replace them all.
  4. Siena
    Siena Active Member
    2,626
    Izzy, is your Bora a PD model?
  5. Izzy1
    391
    10
    i think it is.
    how do i check? is it the way the engine sits?
    if so then it sits normally. and not sideways if that makes any sense.
  6. Siena
    Siena Active Member
    2,626
    Not referring to the layout - the Bora engine / tranny is transversely-installed though.
    PD refers to the type of diesel delivery - "Pumpe Duse". Each injector is a high-pressure pump.
    You can tell if it's a PD unit - it won't have the diesel injector pump, that's cambelt driven.
    If you're not sure, you can PM me the engine code - what power output is it?
  7. Izzy1
    391
    10
    Siena,
    PM sent.
  8. Siena
    Siena Active Member
    2,626
    No worries, Izzy.
    Sounds like you've got a PD engine - injector failure isn't uncommon, though i hope in your case, it's not the case.
    PD injectors are about £600 each, you don't want to be buying one or more of them!
  9. Izzy1
    391
    10
    :wtf:
    thanks for this Siena.
    i'm taking the car to the garage after work around 5 so will find out if i should cry or not.
    will keep you posted on what my mechanic says.
  10. Siena
    Siena Active Member
    2,626
    Izzy, no worries, good luck with things.
  11. electricracer
    electricracer Member
    149
    if your engine is the type (not sure of code) that the wiring loom for the injectors is inside the rocker cover(in the oil) then i would suspect this first, done a few of them always comes up with injector fault
  12. Izzy1
    391
    10
    electricracer i know what you mean that normally is the cause but mine seems to be misfiring badly.
    took it to my mates garage yesterday (vw&audi specialist) told me it's the cylinder so i'm getting that replaced with a second hand one. total damage is £150 so i'm giving this a try and hopefully it will solve my problem.
    picking up the car tonight so will see if it's worked.
