OEM Xenon Headlamp Conversion - Part Numbers
Addie May 4, 2011
  1. Addie
    Addie Member
    74
    Hello,
    I want to convert my headlamps to Xenon lamps with the integrated round DRL lamps (as per the RS4). I am aware that factory models also head a headlamp was system, but at this point I was wondering if anyone could help me with the necessary part numbers and a list of items required.
    Headlamps
    Ballasts
    - Different wiring loom?
    Any other physical parts required before making the changes on VAG COM?
    Many thanks!
  2. hades-
    9,481
    646
    headlights
    ballasts
    bulbs
    loom
    vcds
  3. yavz
    yavz New Member
    Pretty much the above is needed.
    I have a pair of complete xenon headlights if your interested. Ballasts, bulbs and all included.
    Drop me a PM
  4. Addie
    Addie Member
    74
    Thanks Yaz - although I'm looking for clear rather then tango ones :(
    Are the headlights with the DRL's like the RS4 bi-xenon? If so they're also adaptive and stuff, right?
    So there are two different types of Xenon headlamps to look out for?
    Can anyone help?
    Cheers,
    A
  5. ultramodz
    ultramodz 06 A4 2.0T FSi S-Line SE
    515
    I did the upgrade - your best bet is to wait for some to come up on eBay - they're very expensive from Audi. I'd let you know the part numbers, but they're hidden now the lights are in the car.
    You'll need a PC laptop with VAG-COM installed, a suitable serial cable, the lights/ballasts/ignitors/etc. and a wiring harness. Kufatec do two versions - I went for the cheaper one that doesn't add auto-levelling.
