OEM Xennon colour temp
V6 Quatt Aug 6, 2012
  1. V6 Quatt
    V6 Quatt Well-Known Member
    1,248
    441
    Hi All,
    Do you know what the OEM Colour Temprature is for my Bi Adaptive Xenons 4300k or 6000k?? even the dealer didnt know
    Not sure as I need to replace a bulb so shopping around.
    Thanks in advance
  2. disco-barry
    disco-barry New Member
    27
    I'm sure somebody else could be more helpful than me but i think it's the Phillips D2S 4100k. If all else fails, take a bulb out and you will get a direct replacement off the part number off the bulb.
  3. rizzini7
    rizzini7 Active Member VCDS Map User
    983
    155
    43
    Mine are D1S??? Or did they change in 2006
  4. Daggerit
    Daggerit Well-Known Member Team Floret Silver TFSI Owners Group Team V6 Audi S4 quattro Audi Avant Owner Group
    1,809
    616
    I don't know if these are the same as my 2010 A3 was but it had 4300K IIRC. I think the OEM standard is usually 4300-5000K though so if you can get something in that range I don't think that it would look much different from standard. Hope that helps!
  5. A4_MaJiK
    A4_MaJiK Azeem
    924
    109
    43
    I believe it's a D1S bulb rated between 4100-4300k in colour temperature. I'm after a pair of 6000k bulbs myself. Can anybody confirm whether bulb types were ever changed from D1S to D2S? I very much doubt it as the headlight unit remained the same.
  6. psychopomp1
    psychopomp1 Member
    167
    15
    I recently got original oem bi-xenons installed on my B7 and they came with Philips 4300k D1S bulbs. However i swapped them for a pair of 5000k Osram Xenarc Cool Blue. The Osram's are far, far better...light is whiter, more range and a lot cheaper than the Philips oem's (around £120+vat from Audi).
    Replacement Osram D1S Cool Blue Intense Upgrade Cool Blue Intense...
    Or you can get then from Germany for 72 euros (or 60 euros exc vat if buying for a business):
    KfZ-Halogen-Scheinwerferlampe Osram Xenarc Cool Blue D1s Intense | voelkner - direkt günstiger
  7. NHN
    29,561
    1,778
    Yeap 4300 & change in pairs as colour will look of.
    B7 have always been D1S, B8 is D3S.
