OEM offset on 18" S3 rims
liam Mar 20, 2009
  1. liam
    liam waiting, waiting, waiting
    171
    Can somebody please tell me what the OEM offset is on 18" 8P S3 rims.
    :beerchug:
    Thanks for the answers which are 18x7.5 ET54.
  2. boggym
    boggym Member
    158
    I'm pretty sure it's 54.
  3. JustCharlie
    JustCharlie Member
    295
    yep ET54
  4. Boydie
    Boydie Boycie VCDS Map User
    3,329
    426
    For your own knowledge, anything between et45-55 is suitable for the A3
    If you go above et55, you will require spacers
  5. liam
    171
    The other question I should have asked, are the OEM rims 7.5" or 8"?
  6. PW-Motorsport
    PW-Motorsport Member
    396
    Looking on Ekta it suggests the 18" oem wheels are all all 7.5x18 ET54mm
  7. Timbo_S3
    Timbo_S3 Member
    57
    There might be some variations. I had a set of original 8P S3 wheels, which were 18x7.5, ET 56. These were off a 2007 build. I currently have a set of RS4 reps, 18x8, ET 42. These rub -- very slightly -- at the rear on the screw holding on the inner guard, at about 11 o'clock. Not big rub, and only if loaded. A little Dremel work will fix it ;)
  8. liam
    171
    Yeah, the BBS CKs rub at the front on the GTI when under extreme cornering load. But it's liveable.
  9. Timbo_S3
    Timbo_S3 Member
    57
    They'll be fine on the S3....hehehehe! ;)
