OEM LED Numberplate Lights without errors 2010+
aky20 Nov 12, 2012
  1. aky20
    aky20 Member
    68
    Hi all,
    I was browsing Kufatec and came across the following adaptor which I have not seen before:
    Adapter plate LEDs Audi A4 B6, B7 / Audi A3 8P-39298-1
    I have the A5 leds fitted, but as the car is on a 2010 plate it brings up an error. Would the above adaptor resolve this and has anyone used it and had any success?
    I imagine it connects to the wiring behind the plastic trim?
    Any ideas guys.
    Thanks in advance!
  2. aky20
    aky20 Member
    68
    Based on me converting some German on the review posted see below it would appear to solve the problem on 2010 cars
    've Audi A3 Sportback 2.0 TDI 140 hp year 2010 8P install Simply for each! and working properly. And the error message is displayed in the FIS NOT more! Thank you!
  3. aky20
    aky20 Member
    68
    Update....
    According to Kufatec this adaptor will resolve the DIS error thrown out by the OEM LEDs.
    I have ordered and awaiting delivery.
    Will keep you posted of progress.
  4. daz.h
    daz.h Member
    59
    :think: i cant understand why anyone would pay that extra price just to have led's fitted to the back, to which you will not see any benifit from.
    i fitted them to my 07 A3, only because a screw had come away from one light and the unit fallen out at some stage, mine work without any warnings, but i would not have gone to the lengths of the above just to have them.
  5. deanshaw24
    deanshaw24 Well-Known Member
    538
    445
    Because they look so much better than halogen ones!
    MrWhItEwOlF and aky20 like this.
  6. Helifella
    Helifella Co-Driver ~ Hattie Staff Member Moderator Regional Rep VCDS Map User
    569
    149
    43
    Did any of you spot the country flag icons (top right)
    Union flag ~ simples
  7. aky20
    aky20 Member
    68
    Right guys an update for you all...
    The wire finally arrived and I have just got around to fitting it from the pictures you will see dedication to the cause.
    This is the wire in the packaging it arrived within.
    Without the packaging.
    Okay clearly had to improvise as lacking a garage and natural light..
    After battling with the boot panel it came off the wire was fitted in 10 minutes
    Wire fitted and working
    No more bulb out light, thank god the bulb light was driving me crazy now I have the low fuel light to look forward tooo.
  8. jb0o
    jb0o North East Forum Moderator Regional Rep Site Sponsor VCDS Map User
    2,662
    116
    Good work mate. Love the outdoor lighting solution, haha.
    slimx likes this.
  9. t8ups
    t8ups Site Sponsor Site Sponsor VCDS Map User
    2,018
    723
    on the loom is that 1 resistor per side or 2 resistors for the whole lot?
  10. aky20
    aky20 Member
    68
    Hi t8ups,
    It is that one resister for the whole lot.
  11. phil76
    phil76 Active Member
    572
    40
    I am glad i have seen this as i thought the A5 lights just worked with no faults anyway,how much was the loom sorry? cant open the link from the work computer
  12. aky20
    aky20 Member
    68
    Hi mate,
    I came to about £35 i think for the loom and postage.
  13. Jambo26
    Jambo26 Active Member Audi A3 Black Edition
    422
    25
    do you know if these work on a 2011 A3. i was going to go down the route of replacing the bcm.
  14. T-800
    T-800 Well-Known Member Team Mythos VCDS Map User Team Tornado Audi RS3 quattro DSG
    1,587
    1,254
    Hi Trups is your man on here, just fitted LED's to my 2011 S3 worked perfect all i needed to do was code them with VCDS.
  15. deanshaw24
    538
    445
    I tried coding mine, I have a 2010 s3, but my software wasn't high enough so couldn't code!
  16. poli84
    poli84 Member
    425
    57
    This is my issue also.
    T8ups, do you think you can make a loom to get the OEM LED's working?
    35Euro from Kufatec is too much...
  17. Acheron
    Acheron Active Member
    271
    30
    Likewise here.
  18. Cruiser89
    Cruiser89 Advanced In Car Tech Site Sponsor
    1,484
    221
    Hey guys! Thought I would add my 2 cents on the VCDS coding.
    I had some bright LEDs on my rear plate. Same ones as Warren. Only noticed when a friend was driving behind me that one of them had failed. I didn't get a warning on my DIS. I believe that if you code the car (Think it was called Cold monitoring) then if the light goes, you will get no warning it has.
    To me its not a massive issue, I would rather have the LEDs and no constant DIS warning when fitted.
    Tim
  19. Acheron
    271
    30
    Yup, the coding does nothing to change the resistance tolerances to allow for LEDs...it simply removes the monitoring completely ;)
  20. deanshaw24
    538
    445
    ^^^ how do you code this?
  21. avvy786
    avvy786 Member
    55
    i would just go visit T8ups - has been doing car lighting for quite some time and always has a solution to bulb problems :D as done my car full interior and exterior and till today not experienced any faults :D
  22. poli84
    poli84 Member
    425
    57
    So will this coding work on our MY10 to allow the OEM LED's and can it be done?
    Or does the module (or whatever it is called) need to be updated?
  23. Acheron
    271
    30
    Not sure what your CE unit software version is, but mine appears to be too early for the coding to apply to it yet too new for the LED units to work without removing "cold monitoring". I would think my (and maybe your) best bet would be to go for one of these Kufatec cables.
  24. t8ups
    2,018
    723
    I have sent away for a new mould to be made, i designed it for the RS4 owners so a resistor can be fitted to the bulb rather than buying a loom with them fitted, getting a test bulb next month from the mould so fingers crossed.
  25. Acheron
    271
    30
    Ordered a set of these today: AUDI A3 S3 A4 S4 RS4 A6 S6 RS6 A5 S5 Q7 A8 S8 10' 11' 12' LED license plate lamp | eBay
    Seller seems to swear blind they'll work without the need for coding and/or additional adapters so we'll see when they arrive :think:
  26. poli84
    poli84 Member
    425
    57
    Looks forward to hearing the results T8ups!
    Let us know how you go, pics would be great.
    I'm hesitant about aftermarket LED's as they are typically too bright.
    OEM LED and a loom from T8ups is the best option i think.
  27. Acheron
    271
    30
    They do tend to be a bit bright, especially on lighter coloured cars. It wasn't such a concern on my previous car (a dolphin grey A3), but I had actually taken the unit apart and blacked out a row of LED's on the lens to reduce the amount of light and that seemed to work well.
    I'll be sure to post some pics of them fitted unmodified as well as after I fiddle around with either blacking out rows again OR possibly applying a layer or two of LaminX in their "tint" colour.
  28. rdfcpete
    rdfcpete Member
    138
  29. Acheron
    271
    30
    Right, so the eBay units linked above worked 100%. As predicted they are a bit bright, but I'll be blacking out parts of the lens to see if this fixes it.
  30. rdfcpete
    rdfcpete Member
    138
    Cheers for the feedback - good to know :icon_thumright:
    No DIS errors so far?
  31. brangus
    brangus New Member
    Had mine installed for a week or so now and no faults. They are bright, but I think it looks OK.
  32. rdfcpete
    rdfcpete Member
    138
    More useful evidence if yours is a MY2010+ ?
  33. Acheron
    271
    30
    No issues a week in :)
  34. rdfcpete
    rdfcpete Member
    138
    Cheers. Did you remove the white padding that came on the inside of the units before fitting?
  35. Blackie
    Blackie Active Member
    697
    67
    Aky
    What colour are those rings ?
    Is it brown / black / red / gold ?
    If thats so each resistor is 1kohm
    3 in parallel is 333.33 ohms
    Should be easy enough to make & cost about 5 pence
    £35 my arse
  36. aky20
    aky20 Member
    68
    Erm just checking mate I think that is a correct colour combination, I need to have the boot panel off again in a couple of weeks so can check then for you mate.
  37. aky20
    aky20 Member
    68
  38. bulldog a3
    bulldog a3 New Member
    just ordered these - hope they work on my '12
  39. aky20
    aky20 Member
    68
    Poor fitment in terms of the connections? It should fit okay as its the same connector
    I image that the pins on the led units have been bent to make sure they fit?
  40. downtothebone
    downtothebone Active Member Team Scuba Audi A3 Audi Cabriolet Owner Group S-line owners group
    606
    104
    43
    Worked for me after trying loads of others including the OEM units - seems to be pot luck ...
