OEM Engine Cover mod when CAI fitted
mattandrew Aug 29, 2009
  1. mattandrew
    mattandrew Member VCDS Map User
    977
    21
    Ive had the forge CAI fitted a month or so now and the ugly engine bay has annoyed me since. I looked into after market engine covers and decided against them so came up with the plan to butcher the original OEM cover. So I can put the car back to standard I purchased a spare engine cover from ebay for £50 as a new one from audi is about £130.
    Heres the engine bay before with the CAI fitted, its not the best pic but you all know how ugly they look with the original cover removed.
    I set to butchering the engine cover after I made the first few incisions
    It would of been a bit to much hard work for the dremel so decided on the 9 inch angle grinder, bit over the top but did the job a treat.
    after a few trial fits and a bit more cutting, the finished job
    The modified cover uses the existing two front mounting points. I used a strip of double sided sticky foam along the back edge. The underside back edge sits across the top of the coil packs. I then used a cable tie to secure the cover down
    The finished product fitted to the car
    HHS3 and Levi Saenz like this.
  2. N8
    17,163
    718
    Superb job matt as usual, don't expect anything less from a man like yourself. This is why you are talked about through the village as the 'David Beckham of Tideswell'
  3. Boydie
    Boydie Boycie VCDS Map User
    3,287
    394
    Snazy matt! You didn't mention this on the phone earlier :p
    Great work!
  4. mattandrew
    977
    21
    Cheers, finishes the engine bay of nicely. Just in case it went pair shaped I didnt, lol
    roll on Edition38
  5. N8
    17,163
    718
    Ditto :laugh:
  6. S3Alex
    10,584
    4,651
    Nice work...I can see a bit of DIY coming on.....
  7. Iggu
    Iggu Active Member
    1,229
    Brilliant work Matt - best "aftermarket" solution to this I've seen (better than those crappy EVOMs ones). Just hope that spring washer and threadlocker combo holds out on the Forge !!
  8. VRStu
    VRStu Just Looking VCDS Map User
    1,073
    Looks much better IMHO, I tried the EVOMS cover when they first come out - Rubbish.
    You can leave the rear fixings on if you think about it and cut carefully, I've done a few of these myself.
    You don't have to wait for an Audi cover, they are all the same it's only the silver trim that differs.
    Here's one I had on one of my Octy's -
  9. N8
    17,163
    718
    Is your CAI pipe been powdercoated Stu? Looks awesome black I think...
  10. VRStu
    1,073
    That's an EVOMS, they are plastic. Quite an old picture now - I don't have the car or the CAI.
  11. Staz
    Staz is a retronaut Staff Member Moderator VCDS Map User
    6,206
    64
    Why did no one tell me the EVOMs was **** when I said I was going to order one! :aggressive:
    Great mod Matt :yes:
  12. N8
    17,163
    718
    Cheers for that Stu, Leon, I want buckets, got Matt's car at the mo, I need the buckets..
  13. Staz
    6,206
    64
    You can't have mine mate! :p
  14. N8
    17,163
    718
    :keule: Back to the drawing board
  15. VRStu
    1,073
    The EVOMS is great Leon, it's the cover that's ****.
  16. S.
    S. Well-Known Member Team Ibis TFSI Owners Group Audi S3 quattro Manual
    1,975
    537
    now i have to find 2nd hand engine cover :banghead:
  17. VRStu
    1,073
    Like I said mate it doesn't have to be Audi, you can also carefully remove the Audi centre cover of your original one to use on a non Audi one if you wish.
  18. VRStu
    1,073
  19. S.
    1,975
    537
    yes. but first i have to find cheap one :unsure:
    nice little mod, cause that engine looks like **** :3sadwalk:
  20. warren_S5
    warren_S5 Moderator Staff Member Moderator VCDS Map User
    7,210
    2,483
    I've been told a TT-S one may work well. Obviously it will have to be purchased through dealer so will be costly, but I've been led to believe the MAF isn't attached to the engine cover like on the S3 (save so much modification of the cover). Yet to see one to confirm mounting points.
  21. VRStu
    1,073
    Yeah looks possible Warren, might not be straight forward though. Looks like the front locating peg might be on the top of the inlet manifold so I guess you could fit that but the rears look to be sticking up from the rocker cover.
    Sorry for the big picture but it's better for the detail.
  22. warren_S5
    7,210
    2,483
    hmmm, thanks for that. May not be as easy as first hoped. Can only see 2 uprights to connect it and they are nowhere near the originals. But then if it was easy, it wouldn't be worthwhile!
  23. mattandrew
    977
    21
  24. Levi Saenz
    Levi Saenz S3 FTW!!! like boost???
    So tts engine cover fits with no extra mods??? Cause I'm planning to get a CAI, I like the one of UNITRONIC.
  25. fernando young
    fernando young Active Member
    181
    45
    you need to get these plastic pins, so they hold the cover
  26. Levi Saenz
    Which ones man?
  27. fernando young
    181
    45
    https://c1552172.ssl.cf0.rackcdn.com/393896_x800.jpg
    these, there are different lengths, so i dont know which ones will you need exactly. i think there are needed 3
    2 short and one long that goes on the plastic manifold
  28. Dobermansteve
    Dobermansteve Member Audi S3
    97
    32
    There are two long ones and one short one. Mjr901 (i think) on here may be able to source them for you but it's these metal bolts that are the hard part of the kit to find! They are becoming a bit like hens teeth!
    Levi Saenz likes this.
  29. Dobermansteve
    97
    32
