OEM Bluetooth Kit RETROFIT GUIDE - With Pics :)
a6_chris May 11, 2013
  1. a6_chris
    a6_chris Well-Known Member
    1,883
    160
    .. photobucket died :(
    Muzza80, dk1234, MAD_Adamski and 2 others like this.
  2. Sandra
    Sandra Administrator Staff Member Administrator TeamMisano TFSI Owners Group Audi S3 quattro s tronic Platinum Supporter Audi Main Dealer
    26,994
    9,975
    ​Thanks Chris, very comprehensive and well documented guide. :) x
    a6_chris likes this.
  3. reepers
    reepers Member
    110
    15
    Thumbs up! Cracking write up pal!
  4. a6_chris
    1,883
    160
    Thanks guys - much appreciated ;)
    Hopefully it helps someone out!
  5. Cozza McA
    Cozza McA Crunching The Gears VCDS Map User
    410
    74
    Agin another nice write up.
    I thought blue would be easy but reading this looks a bit more complex.
    I always though the Bluetooth unit went under the passenger seat?
  6. a6_chris
    1,883
    160
    It's not that hard when you ge started, I was scared at the start getting everything together but used the little common sense I have (;)) I soon realised it wasn't that bad in reality.
    The factory position is under the passenger seat but I didn't put it here because:
    1) The P&P loom I bought wasn't long enough and
    2) I didn't want to take even more bits out ;)
    Most of the information I gained off here so credit goes to the OP of the thread I got info from.
  7. BoutTime
    BoutTime Member
    95
    Hi.
    Just wondering about your MIC PNs. I'm in the process of replacing my 8L2 862 373 A factory fitted mic with a 8L1 862 373 A. I have BOSE, and that's how it came from factory. Worked fine for 6 years. What is different about the PN you specify for BOSE? Nice guide.
    Cheers.
  8. Jay A
    Jay A Jay a
    17
    do you have any images of the wires where they go into the plugs as i have bose and of the bluetooth loom i have a plug with 3 wires on and there is alredy a plug in the loom that goes into the headunit, do i add these into the orignal plug that is in think one is blue for can and others are k- and k not sure at moment tho. as well for accessing can gateway i am corect in thinking that you do have to register the rosstec software to be able to change code and access can gateway to access the settings
    If there is anyone in staffordshire who fancys the job tho please get in touch
  9. a6_chris
    1,883
    160
  10. Mikemc
    Mikemc Scooby Slayer VCDS Map User
    1,024
    37
    Followed most of this guide although some of the coding wasn't the same for mine IE changing certain digits would change something random on mine lol,
    I put my module in the glovebox where the cd changer should be until I have minute to throw it under the seat
  11. a6_chris
    1,883
    160
    Thanks for the feedback :)
    I did state the coding could be different ;)
  12. Jay A
    Jay A Jay a
    17
    yes please chris if you could take the odd photo of the loom where it goes into back of the stereo with the 2 little plugs and the wires which i have
    green tel+
    black tel-
    and blue k diagnose which on a bit of paper that come from the ebay seller says :
    K- DIAGNOSE nr 5b use only audi A4, A6. on audi a3 ignore this cable and do not conect
    thing is there is alredy a plug in for something else on the car, which is it safe to splice in?
  13. Jay A
    Jay A Jay a
    17
    I was talking to a guy who does diagnostics and auto electrics other day he said to me something about the wires can go straight in and it runs off the bose? he did seem sketchy is some things he was saying but sounds sort of right, am i right into thinking then that its posible to just splice into the plug? or if there is anyone in staffordshire who fancys the job :D
  14. MAD_Adamski
    MAD_Adamski Member
    344
    very useful guide however the coding in step 4 is wrong the code should be 0001222 .... i used this guide and coding not the coding i was given as when i browsed over the instructions i thought they were the same but it seems A-6 chris has missed a digit this was why my mode button was not working and i couldn't scroll through the contacts... HTH others
    Ad
  15. dk1234
    dk1234 Member
    197
    nice guide.
  16. theblueflash
    theblueflash New Member
  17. a6_chris
    1,883
    160
    I can't edit my first post!
  18. theblueflash
    Thanks fella. Unfortunately I gave that a go as well. No luck either
  19. Phil-1
    Phil-1 Well-Known Member Regional Rep
    2,014
    660
    Sorry I'm a it confused over the part numbers for the modules.
    If it's 8P0 862 335 ending in an A to Z it's ok?
    Or 8P1 862 335 A only that is also ok? Anything else steal clear?
    Phil
  20. Phil-1
    2,014
    660
    Someone please help me.:sorry:
    I really want to do this over the coming weeks. but don't want to get the wrong bits.
    Phil
  21. MAD_Adamski
    MAD_Adamski Member
    344
    Phil why not just buy the kit from nhn On here...!? I bought a kit brand new off a supplier before I realised he did the kit cost me about 200 which is very reasonable I feel...
  22. Phil-1
    2,014
    660
    I thought he only fitted. Should have asked him ;-)
    Phil
  23. Phil-1
    2,014
    660
    Anyone know the difference between the "light" version compared to the "High" version?
    I have seen several unit for sale in Germany.
    Thanks Phil
  24. Phil-1
    2,014
    660
    I have spoken to NHN and he only fits them now.
  25. Jkevs
    Jkevs Member
    100
    13
    Hey guys, mite be a stupid question but i've got a 2008 8p s3, it's got some sort of hands free option on it. It's screwed onto the dash next to the standard audio unit. I just thought I'd ask before buying a £110 iphone 5 adaptor only to find it's not guna work lol. Any hell would be highly appreciated.
    Jack.
  26. Phil-1
    2,014
    660
    Put a photo up. Sounds like a phone cradle
  27. Phil-1
    2,014
    660
    Seen a complete kit for £200.
    Looks like that's going to be the best option
  28. Jkevs
    Jkevs Member
    100
    13
  29. Phil-1
    2,014
    660
    I think it's the base for a hands free cradle. But I'm new too so might be wrong.
    I'm sure someone will come along and put us right ;-)
  30. Jkevs
    Jkevs Member
    100
    13
    Atleast I'm not alone then lol yeah hopefully someone will be able to tell me
  31. MattKeating
    MattKeating Member
    248
    17
    I Have the same in my car, and it has the BOSE system too. Just took a quick pic:
    Id like to get bluetooth working in my car - its a 2006 Sportback - would I need anything other than the bluetooth module?
    EDIT- Also the wiring loom & MIC ?
  32. Jkevs
    Jkevs Member
    100
    13
    Mines the same as that, but I have the double din Bose system. I'd just like to know what the cradle does apart from hold the phone see if it's worth buying it
  33. MattKeating
    MattKeating Member
    248
    17
    What was the outcome of this? I'm also a bit confused.
    This would be ok ? ebay
  34. Phil-1
    2,014
    660
    Don't know I'm still waiting for a reply ;-(
    If I can get the module and cable it looks a quick fix
  35. phil_w
    phil_w Active Member VCDS Map User Audi A4 Audi Avant Owner Group S-line owners group Team Brill Red
    602
    57
    If you've got a multifunction steering wheel it should just be a question of pairing to bluetooth - no need to use the cradle. Use phone through the DIS.
  36. Phil-1
    2,014
    660
    Well just been to Audi to enquire about what module wiring and Mic I need to retro fit this and was told "Audi don't support retro fitting parts. When it comes in for service it could be disconnected" he wouldn't even give me a price for the bits ;-(
  37. phil_w
    602
    57
    Yep Audi won't acknowledge that it can be done....
  38. Phil-1
    2,014
    660
    I have read all the post regarding this, but still can't find the answer to some questions I have
    What's the best module for my MY09 S Line, "light or High"?
    Will a unit from an A4 fit?
    Phil
  39. Phil-1
    2,014
    660
    At last I got around to fitting the wireing. Still need to sort the module as the I got got was wrong and not as advertised.
    One thing I struggled with was the Mic install. After removing the trim around the interior light and placing it in the boot. I struggled to understand where the Mic fitted. It goes on the coloured trim piece that you remove first, when taking the interior light out
    Here is a photo that might help someone else that's doing this.
    Phil
  40. Andy1608
    Andy1608 Active Member
    615
    204
    43
    Phil did you have any look with the guy from fleebay and sending you the wrong module?
