OE look aftermarket Led tail lights Avant
tuffy Jan 19, 2013
  1. tuffy
    tuffy Member
    314
    13
    Hi guys
    Quite like the idea of upgrading my standard tail lights on my silver Avant to some Led's. Really want to keep as close to OE look to the tail tights as possible.
    Looked on the FK tuning site, just so many! need help getting close to the OE look
    Anyone help please??
  2. V6 Quatt
    V6 Quatt Well-Known Member
    1,248
    438
    Try to stick to Red and black combination as that will look more OEM
  3. Darren198712
    Darren198712 Member
    194
    14
    I fitted some to my brothers car. I can't remember which ones they were but they looked pretty OEM. I think as long as they are not chrome/silver and don't have the outer black edge they look quite OEM. the lights are amazing and change the look of the car. im after a set myself. I think in feb or april time. also I had to swap the wires around on the fog lights as they were the wrong way round but apart from that they fitted perfectly.
  4. tuffy
    tuffy Member
    314
    13
    Thanks for that. Are the FK Tuning ones fault free? just a straight swap with no wire cutting/swapping?
  5. Darren198712
    Darren198712 Member
    194
    14
    I brought mine from ebay for a saloon. I assume they are they same as the FK ones. they should of been a straight plug and play but the fog lights and the inner side lights did not work so I figured out that the wires were incorrect (wrong way round) so I cut the wires on the chassi loom and swapped them around. (no big deal) apart from they look great. im just saving up do fix up my own car at the moment as I had to fork out for a turbo and intercooler.
  6. tuffy
    tuffy Member
    314
    13
    Cheers Darren, Anyone else got ant imput on the FK lights in general?? Some pictures/links to OEM looking ones would also be handy
  7. Whopper
    Whopper Active Member
    278
    43
    Fk lights them selves are great. Except the Foglight issue just need to swap positive and negative over! No biggie just don't expect it from a new unit?
    FK CUSTOMER SERVICE IS SHOCKING! Please try and contact to see if they have them in stock before you order!
  8. tuffy
    tuffy Member
    314
    13
    Thanks whopper, great help. Does anyone know if the rear lights on the Avant are exactly the same size as the saloon? Or are they different ??
  9. hades-
    hades- Yorkshire & Humber Rep. Regional Rep VCDS Map User
    9,480
    646
    avant and saloon are diffrent
  10. Darren198712
    Darren198712 Member
    194
    14
    that is what I had to do with mine. I thought it was faulty and then I worked it out after. no big deal just cut it and re solder
  11. Whopper
    278
    43
    Yeah exactly that Darren! I emailed them on the 18th December..... I'm still waiting for a reply?!
  12. Rastamouse
    Rastamouse Welsh Audi Nut
    379
    19
    +1 on customer service,awful. Ordered lights and they were in stock, only for them to say 4 days later they were out of stock and not back in till end of jan. so ok was going to wait for them, only for fk to just cancel my order and issue me a refund.
    Managed to get through to customer service eventually after searching for numbers and trying for ages, only for them to be so unhelpful.
    Good products - **** customer service!!
  13. tuffy
    tuffy Member
    314
    13
    Have FK recognised that there is a error in the wiring set up? Or is customer services so bad you don't get the chance to actually tell anyone !!!
  14. tuffy
    tuffy Member
    314
    13
    Just wondered if anyone else other than FK supply after market led rear lights??
  15. Danny-boy
    Danny-boy Member
    490
    20
    No, I bought some for my saloon a month ago and had to rewire them.
  16. tuffy
    tuffy Member
    314
    13
    Thats hopeless!!! They must be aware of it! ..... Unless they are just working their way through old stock.
  17. NOZ
    NOZ Member
    208
    21
  18. Danny-boy
    Danny-boy Member
    490
    20
    The wiring is not good, especially something costing over £200.
    I just rewired them, didn't bother telling them about it.
  19. jdp1962
    jdp1962 Grumpy Old Moderator Staff Member Moderator Team V6 TFSI Owners Group Gold Supporter Team Tornado quattro Audi S4 Black Edition s tronic
    8,042
    2,494
    NOZ, to be clear, if I get a set of LED rear lights from this supplier, is it right that, firstly they will plug in directly into the existing wiring connectors without modification, and secondly, they have resistors built-in so ensure no bulb warning errors?
  20. NOZ
    NOZ Member
    208
    21
    correct my friend just plug in and switch on simples........:yes:
  21. NOZ
    NOZ Member
    208
    21
  22. jdp1962
    8,042
    2,494
    Splendid! That'll be my task for next month, once the service and MOT are out of the way.
  23. NOZ
    NOZ Member
    208
    21
  24. jdp1962
    8,042
    2,494
  25. tuffy
    tuffy Member
    314
    13
