Odometer from kilometers to miles
x1nick Aug 9, 2012
  1. x1nick
    x1nick Member
    37
    Hi
    My odometer has switched back to kilometers, I have bought a ross tech cable to correct this amongst other things.
    I have figured out that in VCDS I would probably need to go to 17-Instruments then to CODING
    Now this is where I am a little stuck, I am assuming I need to change the country code back to 4 (was in another post back on here)
    But how do you actually do this?
    As I have software coding
    Workshop code
    Importer number
    Equipment number?
    Not too sure what I am doing here and don't want to screw it up
  2. x1nick
    x1nick Member
    37
    Found this
    Vcds - How To Switch Display From Miles To Km? - VAGdrivers - sponsored by Alloy-Wheels.ie
    Code:
    {Instrument Cluster}
    Control Module Coding
    Select 17 (Instrument Cluster)
    Coding -> Function 07
    00??x0x: Extra-Options
    +01 - Brake Pad Warning active
    +02 - Seatbelt Warning active
    +04 - Washer Fluid Warning active
    +16 - Sedan (Jetta)
    00xx?0x: Country-Setting
    Note: Germany is coded as Europe, but 0 is a valid for germany.
    1 - Europe
    2 - USA
    3 - Canada
    4 - Great Britain
    5 - Japan
    6 - Arabian States
    7 - Australia
  3. NHN
    29,596
    1,782
    Use the DIS settings with wiper stalk mate, very easy to do :)
