Odd vibration in MY A3 8P
scott909 Mar 16, 2014
  1. scott909
    scott909 New Member
    24
    Hi All,I have an odd vibration problem with my A3 2.0T 8P 2005 S-Line. It is very hard to describe but I would say it's worse at around 50-70mph and other than these speeds, very little vibration. The vibrations are felt throughout the car and the steering wheel.I've tried having all wheels aligned and calibrated to no avail.Getting very frustrated and any ideas or input is much appreciated.ThanksScott
  2. Walts2782
    Walts2782 Active Member
    243
    61
    Have the wheels been checked and balanced?
  3. max69vk
    max69vk Active Member
    862
    57
    Tyre deformity?
  4. JulesW
    JulesW New Member
    Could be a dented wheel or balancing weights missing
  5. Jonny54
    Jonny54 Member
    41
    I recently had this problem, at first with a bulge in a tyre, and then with missing ballancing weights on one side of the wheel.
    Sounds steriotypical to be more noticable between 50 and 70 as well so i would strongly suggest that, likely that google would confirm as well man.
    Take your care to a garage, Checking a wheel for ballancing is usually free of charge, if its not ballancing it wont cost you money, if it does need ballancing then itll only be a few quid :)
    Hope that helps bro
  6. JAMI308
    JAMI308 Jamie H - Cumbria
    62
    I had the same when I first bought my car, quick trip to HiQ when I got home with the car... tracking / balancing done and the car felt like a new car! Cost about £20 all in!
  7. scott909
    scott909 New Member
    24
    The wheels have been balanced. I'll take the car in to the local tyre place and get them to check them over for tyre deformity. Thanks for all your help.
  8. Jonny54
    Jonny54 Member
    41
    Good plan man, Let us know what happens please :)
  9. Hoesty
    Hoesty Active Member
    228
    I had this same problem when I fit 19" wheels from 18". Turned out to be hub rings needed to be fitted on all four wheels to finish a tighter and more secure fit. A mentioned though, could be
    many of the mentioned in previous posts. Hope you get it sorted cos it annoyed me just for 5 days. Wheel shop had to order them in.
  10. scott909
    scott909 New Member
    24
    Went to the local tyre shop today and they had a look. Turns out my rear N/S wheel is damaged and was therefore producing vibration through the car. They've temporarily swapped it out for an old used (working) one and voila, vibration is gone! They will make the repair of the wheel in the next couple of days and all should be well. Thanks everybody for your input!
    Hoesty likes this.
  11. Hoesty
    228
    Glad you got it sorted
  12. lgooch
    lgooch Well-Known Member VCDS Map User
    1,165
    158
    I have just suffered 2 buckled wheels. Felt like a pneumatic drill was in the car with me. Doesn't take much to spoil the ride.
