Odd boost cut on WOT after DV service?!
Gops May 15, 2013
  1. Gops
    3,198
    666
    Hi guys! So been busy sorting things out but now I have a bigger problem!
    yesterday I changed my MAF for a brand spanker.. Car seemed fine under WOT. Today I pop on an s2000 filter so I can clean my JR one. Fine no problems. Then I service my DV and tried to do logs, it cut when I changed into 4th. Now if I'm in 1st gear it'll cut the power like the ESP has kicked In but it's turned off? 2nd seems ok but has flat spots. 3rd is the most odd. It has a flat spot from 2-4k rpm and then it'll kick in? I'm baffled, I did the DV service correctly, no codes are throwing up.. Anyone have an insight, or know which blocks I should log?
    Many thanks guys.
    Gops
  2. Paradox1
    Paradox1 Well-Known Member
    1,833
    88
    check for leaks
    1st step.
  3. badger5
    9,510
    2,004
    blocks 002,020,115 for starters
  4. Gops
    3,198
    666
    Went to log and the flipping lappy died! Charging it and will post results ASAP. Many thanks bill!
    oh and no boost leaks that I can see.. I thought it was over boost first but ill log and post
  5. Gops
    3,198
    666
    heres the logs as requested.. I have no idea whats what.. First log is 3rd gear. Second log is 2nd gear and the third log is 1-4th before I had o step on the anchors! Please let me know an insight to this!
    [TABLE="width: 1024"]
    [TR]
    [TD]Wednesday[/TD]
    [TD="align: right"]15[/TD]
    [TD]May[/TD]
    [TD="align: right"]2013[/TD]
    [TD="align: right"]19:02:19[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="colspan: 2"]8L0 906 018 N[/TD]
    [TD="colspan: 3"]1.8L R4/5VT G 0002[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD]Group A:[/TD]
    [TD]'002[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]Group B:[/TD]
    [TD]'020[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]Group C:[/TD]
    [TD]'115[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD][/TD]
    [TD]RPM[/TD]
    [TD]Load[/TD]
    [TD]Inj. On Time[/TD]
    [TD="colspan: 2"]Mass Flow[/TD]
    [TD]Idle Stabilization[/TD]
    [TD="colspan: 2"]Idle Stabilization[/TD]
    [TD]RPM[/TD]
    [TD]Load[/TD]
    [TD]Absolute Pres.[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD]TIME[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]TIME[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]TIME[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]Marker[/TD]
    [TD]STAMP[/TD]
    [TD] /min[/TD]
    [TD]%[/TD]
    [TD] ms[/TD]
    [TD] g/s[/TD]
    [TD]STAMP[/TD]
    [TD] CF[/TD]
    [TD] CF[/TD]
    [TD] CF[/TD]
    [TD] CF[/TD]
    [TD]STAMP[/TD]
    [TD] /min[/TD]
    [TD]%[/TD]
    [TD] mbar[/TD]
    [TD] mbar[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]0.02[/TD]
    [TD="align: right"]1440[/TD]
    [TD="align: right"]11.3[/TD]
    [TD="align: right"]1.64[/TD]
    [TD="align: right"]3.03[/TD]
    [TD="align: right"]0.4[/TD]
    [TD="align: right"]0[/TD]
    [TD="align: right"]0.8[/TD]
    [TD="align: right"]1400[/TD]
    [TD="align: right"]10.5[/TD]
    [TD="align: right"]980[/TD]
    [TD="align: right"]990[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]1.2[/TD]
    [TD="align: right"]1480[/TD]
    [TD="align: right"]54.1[/TD]
    [TD="align: right"]7.79[/TD]
    [TD="align: right"]21.08[/TD]
    [TD="align: right"]1.6[/TD]
    [TD="align: right"]2[/TD]
    [TD="align: right"]1680[/TD]
    [TD="align: right"]73.7[/TD]
    [TD="align: right"]1720[/TD]
    [TD="align: right"]1050[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]2.4[/TD]
    [TD="align: right"]1800[/TD]
    [TD="align: right"]77.4[/TD]
    [TD="align: right"]28.14[/TD]
    [TD="align: right"]2.8[/TD]
    [TD="align: right"]3.2[/TD]
    [TD="align: right"]2080[/TD]
    [TD="align: right"]89.5[/TD]
    [TD="align: right"]1890[/TD]
    [TD="align: right"]1240[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]3.6[/TD]
    [TD="align: right"]2240[/TD]
    [TD="align: right"]98.5[/TD]
    [TD="align: right"]9.43[/TD]
    [TD="align: right"]43.08[/TD]
    [TD="align: right"]4.01[/TD]
    [TD="align: right"]4.51[/TD]
    [TD="align: right"]2640[/TD]
    [TD="align: right"]110.5[/TD]
    [TD="align: right"]2100[/TD]
    [TD="align: right"]1610[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]4.91[/TD]
    [TD="align: right"]2840[/TD]
    [TD="align: right"]118.8[/TD]
    [TD="align: right"]13.12[/TD]
    [TD="align: right"]68.64[/TD]
    [TD="align: right"]5.31[/TD]
    [TD="align: right"]5.81[/TD]
    [TD="align: right"]3480[/TD]
    [TD="align: right"]167.7[/TD]
    [TD="align: right"]2140[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]6.22[/TD]
    [TD="align: right"]3760[/TD]
    [TD="align: right"]172.9[/TD]
    [TD="align: right"]17.63[/TD]
    [TD="align: right"]126.31[/TD]
    [TD="align: right"]6.61[/TD]
    [TD="align: right"]7.01[/TD]
    [TD="align: right"]4360[/TD]
    [TD="align: right"]145.9[/TD]
    [TD="align: right"]2110[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]7.41[/TD]
    [TD="align: right"]4480[/TD]
    [TD="align: right"]96.2[/TD]
    [TD="align: right"]10.66[/TD]
    [TD="align: right"]98.19[/TD]
    [TD="align: right"]7.81[/TD]
    [TD="align: right"]8.21[/TD]
    [TD="align: right"]5120[/TD]
    [TD="align: right"]133.1[/TD]
    [TD="align: right"]2070[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]8.61[/TD]
    [TD="align: right"]5400[/TD]
    [TD="align: right"]155.6[/TD]
    [TD="align: right"]18.04[/TD]
    [TD="align: right"]164.08[/TD]
    [TD="align: right"]9.01[/TD]
    [TD="align: right"]3[/TD]
    [TD="align: right"]9.41[/TD]
    [TD="align: right"]5880[/TD]
    [TD="align: right"]191.7[/TD]
    [TD="align: right"]1990[/TD]
    [TD="align: right"]2020[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]9.81[/TD]
    [TD="align: right"]6120[/TD]
    [TD="align: right"]186.5[/TD]
    [TD="align: right"]22.55[/TD]
    [TD="align: right"]217.17[/TD]
    [TD="align: right"]10.21[/TD]
    [TD="align: right"]10.61[/TD]
    [TD="align: right"]6520[/TD]
    [TD="align: right"]1920[/TD]
    [TD="align: right"]1950[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]11.01[/TD]
    [TD="align: right"]6720[/TD]
    [TD="align: right"]27.06[/TD]
    [TD="align: right"]273.86[/TD]
    [TD="align: right"]11.41[/TD]
    [TD="align: right"]11.81[/TD]
    [TD="align: right"]6920[/TD]
    [TD="align: right"]60.2[/TD]
    [TD="align: right"]1710[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]12.21[/TD]
    [TD="align: right"]6480[/TD]
    [TD="align: right"]3.8[/TD]
    [TD="align: right"]1.23[/TD]
    [TD="align: right"]3.22[/TD]
    [TD="align: right"]12.72[/TD]
    [TD="align: right"]13.21[/TD]
    [TD="align: right"]5080[/TD]
    [TD="align: right"]6[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]13.61[/TD]
    [TD="align: right"]5040[/TD]
    [TD="align: right"]6.8[/TD]
    [TD="align: right"]6.94[/TD]
    [TD="align: right"]14.01[/TD]
    [TD="align: right"]14.51[/TD]
    [TD="align: right"]4640[/TD]
    [TD="align: right"]7.5[/TD]
    [TD="align: right"]1030[/TD]
    [/TR]
    [TR]
    [TD]Wednesday[/TD]
    [TD]May[/TD]
    [TD="align: right"]19:04:43[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD]Group A:[/TD]
    [TD]'002[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]Group B:[/TD]
    [TD]'020[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]Group C:[/TD]
    [TD]'115[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD][/TD]
    [TD]RPM[/TD]
    [TD]Load[/TD]
    [TD]RPM[/TD]
    [TD]Load[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD]TIME[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]TIME[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]TIME[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]Marker[/TD]
    [TD]STAMP[/TD]
    [TD] /min[/TD]
    [TD]%[/TD]
    [TD] ms[/TD]
    [TD] g/s[/TD]
    [TD]STAMP[/TD]
    [TD] CF[/TD]
    [TD] CF[/TD]
    [TD] CF[/TD]
    [TD] CF[/TD]
    [TD]STAMP[/TD]
    [TD] /min[/TD]
    [TD]%[/TD]
    [TD] mbar[/TD]
    [TD] mbar[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]1640[/TD]
    [TD="align: right"]3.97[/TD]
    [TD="align: right"]64.7[/TD]
    [TD="align: right"]1740[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]1840[/TD]
    [TD="align: right"]78.2[/TD]
    [TD="align: right"]30.03[/TD]
    [TD="align: right"]2.02[/TD]
    [TD="align: right"]2360[/TD]
    [TD="align: right"]100.8[/TD]
    [TD="align: right"]2010[/TD]
    [TD="align: right"]1220[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]2.42[/TD]
    [TD="align: right"]2680[/TD]
    [TD="align: right"]111.3[/TD]
    [TD="align: right"]61.39[/TD]
    [TD="align: right"]2.82[/TD]
    [TD="align: right"]3520[/TD]
    [TD="align: right"]188[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]3.62[/TD]
    [TD="align: right"]4080[/TD]
    [TD="align: right"]155.5[/TD]
    [TD="align: right"]4.02[/TD]
    [TD="align: right"]5360[/TD]
    [TD="align: right"]187.2[/TD]
    [TD="align: right"]2090[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]5840[/TD]
    [TD="align: right"]152.6[/TD]
    [TD="align: right"]153.56[/TD]
    [TD="align: right"]2.3[/TD]
    [TD="align: right"]5.71[/TD]
    [TD="align: right"]6680[/TD]
    [TD="align: right"]165.4[/TD]
    [TD="align: right"]1970[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]6.11[/TD]
    [TD="align: right"]6880[/TD]
    [TD="align: right"]84.2[/TD]
    [TD="align: right"]5.74[/TD]
    [TD="align: right"]71.58[/TD]
    [TD="align: right"]6.51[/TD]
    [TD="align: right"]6.91[/TD]
    [TD="align: right"]5760[/TD]
    [TD="align: right"]1160[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]7.31[/TD]
    [TD="align: right"]4560[/TD]
    [TD="align: right"]5.3[/TD]
    [TD="align: right"]4.61[/TD]
    [TD="align: right"]7.71[/TD]
    [TD="align: right"]8.11[/TD]
    [TD="align: right"]4400[/TD]
    [TD="align: right"]1040[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]8.51[/TD]
    [TD="align: right"]4320[/TD]
    [TD="align: right"]6.03[/TD]
    [TD="align: right"]8.91[/TD]
    [TD="align: right"]9.31[/TD]
    [TD="align: right"]4160[/TD]
    [/TR]
    [TR]
    [TD]Wednesday[/TD]
    [TD]May[/TD]
    [TD="align: right"]19:05:47[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD]Group A:[/TD]
    [TD]'002[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]Group B:[/TD]
    [TD]'020[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]Group C:[/TD]
    [TD]'115[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD][/TD]
    [TD]RPM[/TD]
    [TD]Load[/TD]
    [TD]RPM[/TD]
    [TD]Load[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD]TIME[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]TIME[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]TIME[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]Marker[/TD]
    [TD]STAMP[/TD]
    [TD] /min[/TD]
    [TD]%[/TD]
    [TD] ms[/TD]
    [TD] g/s[/TD]
    [TD]STAMP[/TD]
    [TD] CF[/TD]
    [TD] CF[/TD]
    [TD] CF[/TD]
    [TD] CF[/TD]
    [TD]STAMP[/TD]
    [TD] /min[/TD]
    [TD]%[/TD]
    [TD] mbar[/TD]
    [TD] mbar[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]1000[/TD]
    [TD="align: right"]16.5[/TD]
    [TD="align: right"]2.05[/TD]
    [TD="align: right"]0.9[/TD]
    [TD="align: right"]0.01[/TD]
    [TD="align: right"]18[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]1.69[/TD]
    [TD="align: right"]68.4[/TD]
    [TD="align: right"]6.97[/TD]
    [TD="align: right"]25.22[/TD]
    [TD="align: right"]2.09[/TD]
    [TD="align: right"]1.3[/TD]
    [TD="align: right"]1320[/TD]
    [TD="align: right"]63.9[/TD]
    [TD="align: right"]1500[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]2.89[/TD]
    [TD="align: right"]3600[/TD]
    [TD="align: right"]60.9[/TD]
    [TD="align: right"]46.08[/TD]
    [TD="align: right"]3.31[/TD]
    [TD="align: right"]2.49[/TD]
    [TD="align: right"]3040[/TD]
    [TD="align: right"]2170[/TD]
    [TD="align: right"]1270[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]4.09[/TD]
    [TD="align: right"]6640[/TD]
    [TD="align: right"]185[/TD]
    [TD="align: right"]16.4[/TD]
    [TD="align: right"]234.81[/TD]
    [TD="align: right"]4.49[/TD]
    [TD="align: right"]3.71[/TD]
    [TD="align: right"]5600[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]5.29[/TD]
    [TD="align: right"]4960[/TD]
    [TD="align: right"]23.78[/TD]
    [TD="align: right"]217.53[/TD]
    [TD="align: right"]5.69[/TD]
    [TD="align: right"]136.1[/TD]
    [TD="align: right"]2220[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]139.1[/TD]
    [TD="align: right"]136.44[/TD]
    [TD="align: right"]6.09[/TD]
    [TD="align: right"]6040[/TD]
    [TD="align: right"]2000[/TD]
    [TD="align: right"]2040[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]7.69[/TD]
    [TD="align: right"]5000[/TD]
    [TD="align: right"]106.8[/TD]
    [TD="align: right"]11.48[/TD]
    [TD="align: right"]109.19[/TD]
    [TD="align: right"]8.09[/TD]
    [TD="align: right"]7.29[/TD]
    [TD="align: right"]6080[/TD]
    [TD="align: right"]1390[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]8.89[/TD]
    [TD="align: right"]5520[/TD]
    [TD="align: right"]181.2[/TD]
    [TD="align: right"]22.96[/TD]
    [TD="align: right"]235.44[/TD]
    [TD="align: right"]9.29[/TD]
    [TD="align: right"]8.49[/TD]
    [TD="align: right"]5280[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]10.09[/TD]
    [TD="align: right"]6240[/TD]
    [TD="align: right"]166.9[/TD]
    [TD="align: right"]19.68[/TD]
    [TD="align: right"]174.72[/TD]
    [TD="align: right"]10.49[/TD]
    [TD="align: right"]9.69[/TD]
    [TD="align: right"]6000[/TD]
    [TD="align: right"]114.3[/TD]
    [TD="align: right"]1980[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]11.29[/TD]
    [TD="align: right"]6400[/TD]
    [TD="align: right"]11.69[/TD]
    [TD="align: right"]10.89[/TD]
    [TD="align: right"]119.5[/TD]
    [TD="align: right"]1650[/TD]
    [TD="align: right"]1960[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]12.61[/TD]
    [TD="align: right"]5440[/TD]
    [TD="align: right"]182.7[/TD]
    [TD="align: right"]21.32[/TD]
    [TD="align: right"]188.5[/TD]
    [TD="align: right"]13.01[/TD]
    [TD="align: right"]5320[/TD]
    [TD="align: right"]185.7[/TD]
    [TD="align: right"]2130[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]13.81[/TD]
    [TD="align: right"]5800[/TD]
    [TD="align: right"]154.9[/TD]
    [TD="align: right"]169.64[/TD]
    [TD="align: right"]14.21[/TD]
    [TD="align: right"]13.41[/TD]
    [TD="align: right"]5680[/TD]
    [TD="align: right"]175.2[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]15.01[/TD]
    [TD="align: right"]27.1[/TD]
    [TD="align: right"]2.87[/TD]
    [TD="align: right"]15.41[/TD]
    [TD="align: right"]14.61[/TD]
    [TD="align: right"]138.3[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]16.28[/TD]
    [TD="align: right"]4720[/TD]
    [TD="align: right"]8.3[/TD]
    [TD="align: right"]7.08[/TD]
    [TD="align: right"]16.7[/TD]
    [TD="align: right"]15.81[/TD]
    [TD="align: right"]5240[/TD]
    [TD="align: right"]1130[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]17.5[/TD]
    [TD="align: right"]4680[/TD]
    [TD="align: right"]9[/TD]
    [TD="align: right"]8.31[/TD]
    [TD="align: right"]17.1[/TD]
    [TD="align: right"]4840[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]18.89[/TD]
    [TD="align: right"]4440[/TD]
    [TD="align: right"]19.29[/TD]
    [TD="align: right"]18.49[/TD]
    [TD="align: right"]4920[/TD]
    [/TR]
    [/TABLE]
  6. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Air flow is all over the place, showing 340ish bhp at one stage.......is that your little summat?....;)
  7. Gops
    3,198
    666
    LOL I knew it was quick but that would bend a rod! What does all ths mean then?
  8. Scullies
    Scullies Well-Known Member
    1,543
    657
    is it a genuine bosch MAF ?
  9. Gops
    3,198
    666
    Yeah got it from TPS. Could it be the maf..?
  10. Gops
    3,198
    666
    Anyone?
  11. Gops
    3,198
    666
    Well I think I had a dodger maf connector. I binned the s2000 filter as it was way to oily! I'm about to log again as I haven't had that judder since I fixed the connector..
    This is what I got with the s2000 filter:
  12. Gops
    3,198
    666
    Put the JR filter back on and logged this..
    [TABLE="width: 1088"]
    [TR]
    [TD]Friday[/TD]
    [TD="align: right"]17[/TD]
    [TD]May[/TD]
    [TD="align: right"]15:10:27[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD]Group A:[/TD]
    [TD]'002[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]Group B:[/TD]
    [TD]'032[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]Group C:[/TD]
    [TD]'115[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD][/TD]
    [TD]RPM[/TD]
    [TD]Load[/TD]
    [TD]Lambda[/TD]
    [TD]Lambda[/TD]
    [TD]Bin. Bits[/TD]
    [TD]Bin. Bits[/TD]
    [TD][/TD]
    [TD]RPM[/TD]
    [TD]Load[/TD]
    [TD="colspan: 2"]Absolute Pres.[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD]TIME[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]TIME[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]TIME[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]Marker[/TD]
    [TD]STAMP[/TD]
    [TD] /min[/TD]
    [TD]%[/TD]
    [TD] ms[/TD]
    [TD] g/s[/TD]
    [TD]STAMP[/TD]
    [TD]%[/TD]
    [TD]%[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]STAMP[/TD]
    [TD] /min[/TD]
    [TD]%[/TD]
    [TD] mbar[/TD]
    [TD] mbar[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]0.85[/TD]
    [TD="align: right"]90.2[/TD]
    [TD="align: right"]8.2[/TD]
    [TD="align: right"]29.25[/TD]
    [TD="align: right"]-0.8[/TD]
    [TD="align: right"]-3.9[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD="align: right"]0.45[/TD]
    [TD="align: right"]1520[/TD]
    [TD="align: right"]83.5[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]2.06[/TD]
    [TD="align: right"]2120[/TD]
    [TD="align: right"]10.25[/TD]
    [TD="align: right"]47.25[/TD]
    [TD="align: right"]1.25[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD="align: right"]1.65[/TD]
    [TD="align: right"]101.5[/TD]
    [TD="align: right"]1860[/TD]
    [TD="align: right"]1210[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]3.36[/TD]
    [TD="align: right"]2760[/TD]
    [TD="align: right"]154.1[/TD]
    [TD="align: right"]14.35[/TD]
    [TD="align: right"]85.14[/TD]
    [TD="align: right"]2.56[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD="align: right"]2.96[/TD]
    [TD="align: right"]2520[/TD]
    [TD="align: right"]135.3[/TD]
    [TD="align: right"]1560[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]4.56[/TD]
    [TD="align: right"]172.2[/TD]
    [TD="align: right"]16.81[/TD]
    [TD="align: right"]116.78[/TD]
    [TD="align: right"]3.76[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD="align: right"]4.16[/TD]
    [TD="align: right"]3240[/TD]
    [TD="align: right"]169.9[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]5.76[/TD]
    [TD="align: right"]178.9[/TD]
    [TD="align: right"]148.61[/TD]
    [TD="align: right"]4.96[/TD]
    [TD="align: right"]-3.1[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD="align: right"]5.36[/TD]
    [TD="align: right"]4120[/TD]
    [TD="align: right"]178.2[/TD]
    [TD="align: right"]2150[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]6.96[/TD]
    [TD="align: right"]167.78[/TD]
    [TD="align: right"]6.16[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD="align: right"]6.56[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]8.16[/TD]
    [TD="align: right"]163.9[/TD]
    [TD="align: right"]18.45[/TD]
    [TD="align: right"]181.25[/TD]
    [TD="align: right"]7.36[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD="align: right"]7.76[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]9.36[/TD]
    [TD="align: right"]159.4[/TD]
    [TD="align: right"]183.72[/TD]
    [TD="align: right"]8.56[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD="align: right"]8.96[/TD]
    [TD="align: right"]156.4[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]10.56[/TD]
    [TD="align: right"]6840[/TD]
    [TD="align: right"]127.1[/TD]
    [TD="align: right"]15.99[/TD]
    [TD="align: right"]154.42[/TD]
    [TD="align: right"]9.76[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD="align: right"]10.16[/TD]
    [TD="align: right"]6760[/TD]
    [TD="align: right"]158.6[/TD]
    [TD="align: right"]1910[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]11.85[/TD]
    [TD="align: right"]9.92[/TD]
    [TD="align: right"]10.97[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD="align: right"]11.45[/TD]
    [TD="align: right"]1200[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]13.16[/TD]
    [TD="align: right"]6360[/TD]
    [TD="align: right"]9.8[/TD]
    [TD="align: right"]12.28[/TD]
    [TD="align: right"]12.25[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD="align: right"]12.76[/TD]
    [TD="align: right"]6440[/TD]
    [TD][/TD]
    [/TR]
    [/TABLE]
  13. Scullies
    1,543
    657
    Did you sort out the maf plug? How is the car now?
  14. Gops
    3,198
    666
    Car doesn't seem to judder anymore.. Feels pretty much the same as before. I can feel the turbo being quite lazy.. Will have to see what happens when it's at bills!
