SnowHammer
- Joined
- Feb 19, 2008
- Messages
- 17
- Reaction score
- 0
- Points
- 1
- Location
- North West
- Website
- www.solvetheweb.co.uk
Cars been playing up for a couple of weeks occasionaly not starting and rough running also noticed cant here much sound from the dump valve engine - 1.8t AGU no signs of vac leak but could be possible any advice from vag com measurement below would be appreciated Cheers...
Fault codes:
Vag Com
04: tb 2.6 mass flow -0.24g/s mass flow idle
02: 840prm 1ms2ms 2.76 g/s
06 -3.6% lambda 14.8% lambda 12.0 BTDC
Fault codes:
16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal | ||
P0116 - 35-10 - - - Intermittent |
00561 - Mixture Adaptation | ||
14-00 - Adaptation Limit (Add) Exceeded |
Vag Com
