OBD Error Code "p1504" - Help..?
danzman2002 Sep 9, 2013
  1. danzman2002
    danzman2002 New Member
    26
    Hi guys,
    Engine Management light came on a week or so ago, car drives absolutely spot on.
    Plugged it into my OBD cable, came up with error code "p1504", used the software to reset the codes. Driven it 300 faultless miles and it's come back on again!
    I googled the error code and it says something about an air leak - I'm not particularly mechanically minded, I've visually inspected the engine bay but can see anything obvious.
    What I was just wondering was, should I buy VAGCOM, would it give me a more specific error message?
    Any help would be greatly appreciated!
    Daniel
  2. madmike01uk
    madmike01uk Member
    430
    21
    might help if you let us know what engine your car has.
  3. hades-
    9,482
    646
    this guy had the same fault code as you
    Hi There. Found the problem is is a split hose that comes of what looks like the throttle body and travels down under the engine.
    so id say smoke test to find the leak and take it from there
  4. danzman2002
    26
    Sorry, would help!It's an Audi A4 Avant 2.0l FSI
    Will have another look when I get time!Thank you :)
  5. Jules
    Jules Member
    130
    How do you do a smoke test?
