Numberplate Lights
Phantom_A4 May 10, 2011
  1. Phantom_A4
    Phantom_A4 Member
    563
    Hi Guys,
    After trying a few bulbs to see if I could get away with using normal led 39mm festoons (which failed) I did a bit of research and ended up giving in and buying the £30 ones, which are epicly bright how ever still throwing up the light out warning.
    They are the ones you can buy off ebay and replace each unit, was wondering if anyone else had this problem as I heard these are the only ones that don't throw up a warning. >_<
  2. razza1
    razza1 Well-Known Member
    3,053
    804
    I bought them, and had no issue with them causing errors
  3. hades-
    9,481
    646
    i need some have you got a link ?
  4. Phantom_A4
    Phantom_A4 Member
    563
  5. razza1
    3,053
    804
    Yep, same as those
  6. Farhan
    Farhan Active Member
    1,234
    57
    Using very similar ones on my a3 no problems with dash lights, thinking of using a tint spray on the lens to tone the brightness down a bit though
