Number plate lights not working
TwistedMind Oct 13, 2012
  1. TwistedMind
    TwistedMind Long Live The A6
    115
    Hi all, new problem
    My number plate lights have stopped working. Lamps are ok and there is no voltage at the terminals.
    Do the wires connect back to the rear lights, or are the on a seperate circuit ?
    Help, before i get pulled !!
  2. wesmaster
    wesmaster Member
    300
    20
    I would start looking at the wiring when the boot shuts, normally breaks there, open close open close and so on.....
    Also check the earth is good.
    TwistedMind likes this.
  3. TwistedMind
    115
    Webmaster, thanks for the time. Saved me alot of greef.
    I jiggled the cables from the boot lid to the car, and yes number plates were like a disco !!
    How do i repair ? Do i split the rubber and resolder ? Then just use tape to reseal ?
    Just worrid about water ingress.
    Mind
  4. wesmaster
    wesmaster Member
    300
    20
    release rubber boot and peel back, solder, heatshrink and done. Can be tricky if the rubber boot wont peel back, get a helper.
    Good luck!
  5. ms1083
    ms1083 Member
    148
    I had similar problem but it was the tube supplying the rear washer that cracked in this joint, caused water to trickle in both directions causing very annoying water stain around rear boot light and soaking inside of boot trim. Easy to repair but bit fiddilly, especially working out which bits of trim pull off, in which order and where the hidden screws are.
  6. TwistedMind
    115
    Split the rubber open, 2 broken wires and the rest broken down to bare copper. Re soldered and fixed.
    Thanks for all the help. Be lost without this forum !!!
    Mind.
