Number plate light problem
munchkincoupe Sep 23, 2012
  1. munchkincoupe
    munchkincoupe Member
    948
    19
    Right - I got the non-led number plate bulbs from T8ups as I had issues with the led ones on my A3 previously. Gone to fit them into my A4 Avant today. Fitted the left holder + bulb - changed screw for stainless steel allen screw - applied some black rubber sealant as the rubber seal had started to perish - tested it and all good apart from the fact that the right light now doesn't work with the normal bulb in it. So went to swap that one out and found that previous owner had rounded off the original screw, must have cut out the old holder, fitted a new one and fitted a self tapping screw at an angle to bypass the rounded off screw shaft! On removing it there has been a lot of water ingress as the angled screw isn't allowing the holder to sit straight in the cut-out
    Whatever I do here the new holder will need to be stuck in somehow so without replacing the whole black strip I feel the best thing to do would be to bond or glue the new holder in place. So here's the question........
    What will last longer (as I won't be able to remove it if stuck in!) an OEM holder with a non-led bulb or the integrated 18 led units that come as part of the holder?
    Also what would be the best product to bond it in with please?
    Thanks for any advice
  2. quattrojames
    14,060
    583
    I'm not too sure what bit is knackered, can't you just buy a new one of these?
  3. glenandem
    glenandem Active Member
    786
    64
    hi guys newbie here,do you know how much them trims are by chance?
    my new avant had one of the no plate bulbs not working only to strip it and find it all corroded away totally and requires a full new strip now!
  4. munchkincoupe
    948
    19
    Yes but it's £30ish for that part plus a new pair of OEM holders and then the time to fit it so figured it may be easier to do one of the options in the first post
  5. Sorry to jump on this thread, i have a similar issue, i had a number plate light out went to replace, screw was rounded, and inside of light was corroded to the point the holder had completely disintigrated, do you have a part number for this as i think i need one too
  6. quattrojames
    14,060
    583
  7. NathanA4Avant
    NathanA4Avant Member
    49
    I've just done this on my Avant. Purchased LED bulbs, and found a self tapper in the light at an angle - must be a dealership fix!
    I removed the panel, drilled out the broken bolt, re-tapped, coat of satin black (left over from the peeling wiper arm job the weekend before!) and replaced both light lenses with new units.
    I would suggest either repairing the housing or replacing it. Gluing the lights in seems like a bad idea....
    Nathan.
  8. munchkincoupe
    948
    19
    Bought a new strip and holders today from audi - another job on the list!
    Thanks for advice fellas
  9. munchkincoupe
    948
    19
    Replaced it all today and working great now. Also stripped down boot handle and relubed it and the boot release works like a dream too now. Getting the trim off was a pain in the a** though
    Avant part numbers - black metal moulding strip - 8E0 827 576 3FZ
    Bulb holders - 8E0 807 430 B and 8E0 807 430 A
  10. BahnStormer77
    BahnStormer77 BahnStormer
    2,773
    60
    Might be, but I would have thought they'd say "new trim": more likely just a well known workaround to the screws corroding and snapping and not having to waste the time and parts to get your motor back on the road.
    I had the same on mine the first time I checked it: a TINY dab of clear bathroom silicon sealant the first time I "resealed" it and it popped back out fine afterwards when I had ordered the new bulb holders. I filled the angled hole with silicone sealant and because there was still a snapped-off screw in the trim, I put a new, small, self-tapping screw in at an angle.... seems to be fine, but just a better seal than the previous setup had (sits completely flush and no water ingress).
  11. glenandem
    786
    64
    hi pal,how much where both these parts,ive got a bulb gone but found the old bulb contacts corroded away plus the whole black metal strip is corroding too!
  12. munchkincoupe
    948
    19
    Moulding - 29.61
    Bulb holders - 7.58 each
    not with vat
    They also do a black plastic version of the moulding that comes with a pair of bulb holders included in the price for about £65 - apparently it was produced to stop the corrosion problem
  13. glenandem
    786
    64
    cheers pal,double the price for plastic!
    you'd think it would be cheaper,well i better get mine done soon got the mot coming up!
