Number Plate Light Help! Slough
Sunny 317 Aug 27, 2014
  1. Sunny 317
    Sunny 317 New Member
    24
    Hi there guys. Im having issues with one of my number plate lights not working and im not the best with taking things apart and was wondering if there was anyone local to Slough that could give me a hand!! Probably would need changing the whole unit. Would be willing to pay aswell, just dont fancy going to a garage who will bump me right off!!
    Cheers!! Sunny
  2. Macdoon
    Macdoon Well-Known Member Team Ibis TFSI Owners Group Gold Supporter Audi A4 S-line owners group
    2,027
    801
    Hi Sunny, firstly welcome to the forum.
    The number plate light unit is very easy to remove/relocate, only minor issue is the tiny screw holding the units in place, they tend to round off so would probably be best to replace those. More than like just a bulb, but sometimes the contacts just need a wee clean.
    jdp1962 likes this.
  3. jdp1962
    jdp1962 Grumpy Old Moderator Staff Member Moderator TFSI Owners Group Team V6 Gold Supporter Team Tornado Audi S4 quattro Black Edition s tronic
    8,642
    3,204
    Hi, Sunny
    Macdoon is spot on, both with the welcome (which I endorse) and the advice on how to check your number plate light. Each light is a single assembly retained in place by one small (and rather soft) cross-headed screw. Most likely fix is a blown bulb, but an all-round clean of the contacts will help too.
    Your friendly neighbourhood Audi dealer will supply the screws separately, so if you do need new ones after removing and fixing your light, it shouldn't be a problem.
    Macdoon likes this.
  4. Sunny 317
    24
    Hi guys. Thanks for the replies. Ive replaced the bulb and cleaned the contacts but still nothing. What would I do next. This one light not working really annoys me :(
  5. jdp1962
    8,642
    3,204
    Oh dear, that does sound like you have more of a problem. Where are you based? Knowing where you are might mean we can steer you in the direction of a forum member near you who's more technically-minded.
  6. Sunny 317
    24
    I know. I wish I had more of a clue on what to do! Im based in Slough, Berkshire. Even West London is fine also.
  7. jdp1962
    8,642
    3,204
    Sorry, just realised, you said Slough in your first post. Well, hopefully, one of our more technically-gifted members will read this and be able to offer some more information.
    One though does occur; if you decide you need to get it looked at professionally, are you familiar with Fontain? It's a non-franchised independent Audi specialist based in Iver. I've bought three out of the four Audis I've owned from them, and they've done work for me as well.
    They're good and their labour rates won't break the bank like a dealer's will.
  8. Sunny 317
    24
    I am familiar with them. I actually rang them and asked how much it would roughly cost. First he said £75+VAT for checking any loose connections and then if the whole unit needed to be replaced then it would be a couple of hundred pounds. Does that sound right?
  9. A4_MaJiK
    A4_MaJiK Azeem
    924
    109
    43
    Hi Sunny and welcome to the forum!
    Sounds like you're having trouble getting power to the unit for some strange reason. Check power from the wires going to the units first. If that is OK then it will probably be the units which need replacing. I would suggest LED units if that is the case. Alot of users run them on here and they also give the car a more modern look too.
    http://www.hids-direct.co.uk/xtec-18-smd-led-12v-high-power-audi-number-reg-plate-led/
    All the best, Azeem.
  10. Sunny 317
    24
    Hi Azeem, it may be the power as I purchased LED units and even tried them and it wouldn't work so clearly cant be the existing ones either. I dont have a clue how I would be checking the power going from where :( I am clueless at these things.
  11. A4_MaJiK
    A4_MaJiK Azeem
    924
    109
    43
    Are they both not working or just the side? Not sure if they are interdependently fused or not.
    Azeem
  12. Sunny 317
    24
    Only one of them has gone out.
  13. S3 finatic
    S3 finatic Limp mode
    106
    Any update to this? I have the exact same problem..
  14. Sunny 317
    24
    Funny enough my instrument lighting setting was on low and I turned it to full and straight away it worked!! How wierd. Since then it has not ever happened again!
  15. sainte986
    sainte986 Vorsprung Durch Technik
    98
    Had a similar issue with mine, lost numberplate lights, fog lights and interior boot light. Traced the fault to a broken earth in the boot. Don't know if that helps.
  16. S3 finatic
    106
    Solved mine!
    One of the lights was not connecting, after a little bit of fiddling I managed to get a circuit.
    Still no power though so disconnected the battery for 15 minutes. BOOM!! i now have 2 working number plate lights.
