number plate light bulb holders
Leaky Lloyd Sep 24, 2010
  1. snowball1969
    snowball1969 Member
    114
    why would you put yourself so much hassle to changes number plate lights to led lights are you mad lol
  2. Shane-Ireland
    Shane-Ireland Member Team Ibis Team V6 Audi S3 quattro Audi A4 Audi Avant Owner Group TDi
    283
    24
    stone mad! your point? lol
  3. snowball1969
    snowball1969 Member
    114
    hehehe, ok you must be lol
  4. quattrojames
    14,050
    577
    If you have to ask then you're never going to understand .....
  5. snowball1969
    snowball1969 Member
    114
    looks like I wont hehe
  6. Turkster
    Turkster Bro.Paul 2.5TDI Quattro Sport
    2,797
    Its no real secret that we are possibly mad and im most defiantly warranted to be certified as "weird" which i kinda take as a complement from my local JW's office when i got invited in for a chat about God and was asked to leave after drank all there coffee and i asked far too many questions that they had no reply too,
  7. Shane-Ireland
    283
    24
    Lol
  8. snowball1969
    snowball1969 Member
    114
    Hahaha
  9. jd26
    jd26 Member
    289
    I have a set of bulbs sitting here (2nd ive had to waste money on actually as first set went walkies) Im now massivly put off bothering if im gonna get the same problem - what a waste of nearly 20 quid on bulbs :\
  10. quattrojames
    14,050
    577
    I couldn't rest knowing that the light surrounds were rusting away inside the tailgate like mine were
    :ohmy:
  11. simon.m
    simon.m Active Member
    2,747
    hmmm just a thought guys if you take it to say audi how much do you think they would charge to change them. i mean if they have all the problems you lot are having do you think they can charge you for that or would you get away with just the price of a bulb change ? reson i say this is if thats all they charge evan if it needs new light holders thats not your fault if they brake the old ones there for cant charge for the new parts im prob wrong mind. and then when its all done you go home and pop the LEDS in ;-)
  12. quattrojames
    14,050
    577
    Nice try mate, but Audi are well aware of this problem, and I'm sure they'd charge you for the new bits required!
  13. simon.m
    2,747
    dammmit worth a thought a ;-) ill leave mine till its a must do then lol
  14. jd26
    jd26 Member
    289
    just to update, i had a quick look - found my balls and went and fitted haha, lucky (for once) and it went straight forward - had to fiddle with one side to get the connection tidy thats all. Easy as peas :)
  15. Martin1981
    Martin1981 New Member
    Had a go at changing mine and thank god the screws came out without too much fuss; I refitted them with LED festoons, HPI R/C screws and a dab of copper grease.
    The pics are ****, but you get the idea..........
    [​IMG] [​IMG]
  16. Higgsy
    Higgsy Hard To Spin
    96
    those LEDs look trick, where can i procure a set o these bad boys??
  17. sc00byd00byd00
    sc00byd00byd00 Frank and Beans............... VCDS Map User
    230
    Have you got one of these tools James ? I want one. removing the interior trim on the Avant is a right bitch to do !!
    I not have an issue that my LED lights stay on (all be it very dim) with lights & ignition off
    Any ideas on how to resolve this ?
  18. quattrojames
    14,050
    577
    I haven't no, I just yanked mine off ..... so to speak .... but did break a couple of the little clips on the way, be careful but firm and you should be ok.
    There must be some small voltage trickle that's keeping them illuminated. Not my field I'm afraid, maybe Woorlord can advise here?
    I got mine off ebay, as did several others from this seller:
    eBay My World - f1autoparts
    The exact ones are no longer available, they just need to be Canbus compatible to prevent bulb errors.
  19. miv
    miv Member
    71
    I'm trying to replace my plinth now as my 1st attempt to just change the bulb holders wasn't the best! I've got the new bulb holders and plinth and have stripped it all back but can't get the old plinth out as it's stuck on the boot lock with that hooked piece of metal. Mine is a saloon so I'm not sure if it's the same as the avant set up but there doesn't seem to be enough room to twist the lock mechanism off the plinth. Any ideas/tips?
  20. Woorlord
    Woorlord shifting to Hyperspace... . VCDS Map User
    951
  21. miv
    miv Member
    71
    Cheers Woorlord, I was missing out the removal of the boot catch! Once that was removed it gave me enough slack to remove the plinth. All changed over now. Thanks again.
  22. Funkyfin2000
    Funkyfin2000 Member
    489
    Any one got any recommendations for decent number plate LEDS. Ive fitted some but they arn't that bright :(
  23. way318
    way318 Active Member
    309
    32
    My boot lid switch has stopped working in the handle the other day and now have to use the remote to open the boot. I took the boot lid trim off today and all around the handle and lock is all corroded, so looks like I will have to replace the lot.
    Does anyone know the part number of the boot lid switch assembly so I can order a new one?
    Will also change the lens covers while I've got the handle off and replace to the screws like suggested in this thread :icon_thumright:
  24. quattrojames
    14,050
    577
    Which part do you mean? Like the bit I fitted in post 65?
  25. way318
    309
    32
    Yes, the bit were you put your fingers to press the boot release switch in the handle, the rubbery bit.
    Can that bit be replaced or can it be stripped down and clean as it must only be a switch of some sort.
  26. quattrojames
    14,050
    577
    The boot release switch is held into the cast surround by a couple of Phillips screws iirc - I just swapped mine into the new cast bit, but I imagine you could strip it down to a certain extent. But I can't confirm, sorry.
  27. Funkyfin2000
    Funkyfin2000 Member
    489
    anyone got any heads up on the LEDS they bought pleaseeee :D
  28. quattrojames
    14,050
    577
  29. way318
    309
    32
    Cheers James, When you press it to open the boot it feels a bit clunky and not as smooth as it did a few days ago, so either something has broken or come loose inside the housing. I'll try and see if I can strip it down to see whats wrong, that way I can get the part number at the same time.
  30. Funkyfin2000
    Funkyfin2000 Member
    489
    Hi guys I bought some M3 20mm screws to replace the audi ones and they are too long!!
    Can anyone recommend any?? Pleeeassee!!!
  31. quattrojames
    14,050
    577
    Can't you cut the bottom off them?
    Put a nut on there before you do, then unwind it off to clean the threads up.
  32. Funkyfin2000
    Funkyfin2000 Member
    489
    Would rather get the right screw if possible.
  33. way318
    309
    32
    Quick question - On the back of the moulding does the micro switch (part that is inside the rubbery handle bit) come part of the wiring loom - Part Number is A8E0 971 145.
  34. Point_Audi
    Point_Audi Vorsprung durch Technik Staff Member Moderator VCDS Map User Gold Supporter Team Tornado Audi A5 Black Edition S-line owners group
    1,383
    966
    Thanks for the advice guys! Decided to tackle this at the weekend, just ended up replace the lens covers. Followed the above steps but removed the unit and had no issues! Cheers
  35. Funkyfin2000
    Funkyfin2000 Member
    489
    I could do with an online heads up on which screws to buy to replace for the lens?
    anyone got a link of what to buy?
  36. Woorlord
    951
    Stainless Steel A2 screws (M3 x 12mm Cap Head)
    Ebay is an easy option to purchase or go to a Fastenings Trade counter.
  37. Funkyfin2000
    Funkyfin2000 Member
    489
  38. Woorlord
    951
    Just check the measurements and must have typed it in wrong originally and in Post #5.
    Thread length from bottom of screw head is 12mm which would suggest screw size is M3 x12mm - changed in post above.
    The total length of the screw from top of head to bottom of thread is 15mm.
    Hope this clarifies the correct size and sorry for wrong info in Post #5.
    :keule:
  39. Funkyfin2000
    Funkyfin2000 Member
    489
  40. Funkyfin2000
    Funkyfin2000 Member
    489
    Thanks dude, appreciated :)
