Number Plate Help!
graham-tdi
chelmsford
Hey guys,
Anyone had a problem with there number plate screws where it just turns but will not come out?
There is some resistance as i turn but it doesn't come loose.
Is there a way of getting around this?
Thanks in advance
Graham
:):greyrs4:
Front or rear?
Rear are normally into threaded holes in the boot lid.
Fronts tend to use self tappers, if they look more like bolt heads you might find someone has used nuts on the back?
Reactions: graham-tdi
Cool cheers.
The ones on the rear are plastic with a flat head slot in them.
Can i get to the back of the number plate anyway?
Put a wedge between the plate and car and try to undo the screw then
So after a bit of fiddling and pulling i managed to undo the last plastic screw.
Thanks for the help guys.
New plates look awesome!
:thumbs up::greyrs4:
