Number plate bulbs out cant fix even with standard bulbs, been pulled 3 times now ???
TDI140 Jul 26, 2013
  1. TDI140
    TDI140 Well-Known Member
    1,632
    175
    Help i cant get them to work ive been pulled over 3 times now and havnt a clue how to make them work again do i need to delete error code via vag com as no thread ive searched clearly tells me what to do
    urgently need help
  2. coreythorny
    coreythorny Active Member
    463
    74
    Have you checked if a fuse had blown?
  3. TDI140
    1,632
    175
    Yes checked but all interior lights and external lights are working
  4. sliced
    sliced Drive safe, stay alive.
    1,572
    335
    Put in new led canbus ones, disconnect battery wait a bit reconect it, should work.
    Driving without rear number plate lights isn't actually as bait as you think, when a cars behind you it's headlamps light up the number plate
    edit: nvm just read the bit about police, just put new ones in then disconnect battery wait then reconnect, for me I didn't have vagcom and originals won't work at all
  5. fangio
    fangio Well-Known Member
    1,542
    187
    Make sure every contact face is scrupulously clean.
  6. sliced
    1,572
    335
    Oh yea make sure it's the correct way round! And make sure the prongs are connecting to it
  7. TDI140
    1,632
    175
    Whats correct way round ? The bulbs ? There the same both sides,
    ill take earth off the battery and wait couple minutes see if it fixes it, got an annoying light on the dash keeps coming and going butbulbs aren't working at all,
    Also connections are squeaky clean i even went and took all the boot lid apart to see if everything is connected and there was no breaks in wires there as well
  8. sliced
    1,572
    335
    Hi mate after my led ones went out, I couldn't get original bulbs to work no matter how long the battery was disconnected for etc, if you got vagcom you should be able to delete the codes and the originals will work.
    If you have a new set of LED festoons, fit them disconnect the battery then reconnect it after a while. I believe the led lights only work one way as its positive and negative sides to it but I could be mistaken.
  9. Artimus
    Artimus Shortback
    2,017
    487
    Yeah they can be tricky to get working after an error! I found it takes a bit of perseverance and plenty of key out, doors locked\unlocked action to clear the fault.
    & yes, as said, the Canbus led's are polarity sensitive
  10. TDI140
    1,632
    175
    Theres few people who have original LED audi ones on there cars from the audi a5 does anyone know part number of them ? Ill go audi and get a set also get new bulb holders just incase they are rust or connections are bad, ill try battery today later on see if it does the trick
  11. TDI140
    1,632
    175
    Just ordered these from audi will they plug and play work straight away ?
  12. smurfworth
    smurfworth Well-Known Member Audi S3
    1,962
    551
    Part numbers:
    4H0 943 021
    4H0 943 022
    They will plug and play and look beautiful too, got them on mine
  13. TDI140
    1,632
    175
    Exactly the same ones ive just ordered from tps, ill fit them and have codes cleared via vag com and hopefully that does the trick :-/
    sliced likes this.
  14. sliced
    1,572
    335
    Let us kno how it goes
  15. Graham89
    Graham89 Derv Perv
    310
    Yes they can be a nightmare to get sorted. When I changed mine for LED's they didn't work for ages. Then all of the sudden they started to work and been fine ever since. Good luck sorting it.
